Old 08-18-2018, 08:43 PM   #1
SliverATX
SliverATX's Avatar
Drives: 2018 Camaro 2SS
2SS Bose Sub install
RF P3D4-10 (2)
RF R1200-1D
LC2i line output converter
ST front firing dual 10 box
ST wiring harness and mic defeat for line out from Bose amp
The lows are definitely filled out now.
SliverATX is offline   Reply With Quote
Old 08-18-2018, 11:41 PM   #2
DC4
DCSr
DC4's Avatar
Drives: 17 50th Anniversary SS
If you don't mind, what did your setup cost and did you install it all yourself?
Thanks,
DC
DC4 is offline   Reply With Quote
Old 08-19-2018, 12:02 AM   #3
SliverATX
SliverATX's Avatar
$530 RF subs & amp, LC2i - Amazon
$270 ST box, Bose harness, mic del, shipping - $ubthump
$150 amp cable kit - Bestbuy
It's a very simple install with a little cutting of the styrofoam for amp cable clearance and a snug fit. The box seems to stay put, but I've got large Velcro strips just in case. The LC2i provides the switched 12v for remote power to amp.
Old 08-19-2018, 07:34 AM   #4
MarkC
MarkC's Avatar
Drives: 2018 HBM 2SS/1LE
Nice
I'm sure it sounds great, but I would have one concern. At low volume levels you'll probably be fine, but if you crank it up for a long period of time I would be concerned about air flow to the amp. It may overheat when pushed.
2017 Admiral Blue Corvette Grand Sport Convertible
MarkC is offline   Reply With Quote
Old 08-19-2018, 10:46 AM   #5
DC4
DCSr
DC4's Avatar
Thanks! I might follow your lead, a bit more bass would be great!
Old 08-19-2018, 01:06 PM   #6
BrianWilcox
Drives: 2017 2SS
I am replacing all my Bose speakers with Infinity 2 ohms, but will need more bass like your project. What were your settings on the LC2?
Has anyone tried to add subs on the rear deck to save room for the trunk?
Boxed in or open to the trunk?
BrianWilcox is offline   Reply With Quote
Old 08-19-2018, 11:59 PM   #7
StPeteHyper2.0
StPeteHyper2.0's Avatar
Drives: '16 Hyper Blue 2.0
Looks nice, good job.. I have similar setup in my non-bose. Amps are attached to back of sub box. They do get hot, so keep an eye on that tucked in there. The LC2i are excellent.
StPeteHyper2.0 is offline   Reply With Quote
Old 08-25-2018, 12:59 PM   #8
Val Walkinshaw
L8ap3x
Val Walkinshaw's Avatar
Drives: 2018 2SS 1LE
Very well done. Your picture now has a home in my downloaded files for future projects.
Val Walkinshaw is offline   Reply With Quote
Old 11-16-2018, 03:19 PM   #9
adamsky27
Drives: 2018 Camaro SS
I'm sure I already know the answer to this question, but... Can the seat be reinstalled in any way with these type of boxes? I'm guessing the subs throw too far and heat would be an issue.
Are there any options to retain the seat?
adamsky27 is offline   Reply With Quote
Old 11-16-2018, 04:00 PM   #10
Wolvie70
Wolvie70's Avatar
Drives: 2016 2SS, Summit White, A8, NPP
Looks to me like that the seat back is just folded down. I imagine that the seat would be able to be put up if needed looking at the pictures.
Wolvie70 is offline   Reply With Quote
Old 11-16-2018, 08:36 PM   #11
StPeteHyper2.0
My seat folds back up.. looks normal. Would never know subs were behind it. No issues with heat. The subs are muffled by the seat slightly or you can leave the seat down. My opinion front facing is better, sound is better throughout cab and no rattling trunk. Bass knob helps with adjusting levels.
Old 11-17-2018, 11:11 AM   #12
FIFTY017
Drives: 2018 Silverado Z71 TxEdition
That all looks good. would like to hear how it sounds!!!! I have a single 12" dvc Rockford sub with 500w amp also. had done while my exhaust and cai were being done. love the sound and doesnt drown out the highs. my box is also ported as i like the lower bass.
FIFTY017 is offline   Reply With Quote
Old 12-16-2022, 12:29 AM   #13
DaffyZL1
Drives: 2019 ZL1 1LE, 1969 Stingray
Originally Posted by SliverATX View Post
RF P3D4-10 (2)
RF R1200-1D
That's very niiiiiiice!
DaffyZL1 is offline   Reply With Quote
Old 12-16-2022, 10:26 AM   #14
ste6000
ste6000's Avatar
how much of a change is your audio and phone calls once the ANC is disabled?
2018 Camaro SS - Hyper Metallic Blue
ste6000 is offline   Reply With Quote
