Old 08-18-2018, 07:55 AM   #1
dfmoeller
Drives: 2018 Garnet Red 2SS Conv M6
Rear Axle Fluid Change
Just looking for some opinions. My 2018 2SS M6 Camaro just turned over 3000 miles. I've heard suggestions that limited slip differentials should have their fluid changed anywhere between 500 miles to 20,000 miles. What is the consensus on this?
Thanks.
Doug
dfmoeller is offline   Reply With Quote
Old 08-18-2018, 12:09 PM   #2
Jsreo
Drives: 2017 2SS Manual
I did, the original fluid was pretty nasty & stinky
I figured it was cheap, easy to do and could not hurt so why not do it?
Jsreo is offline   Reply With Quote
Old 08-18-2018, 01:30 PM   #3
drperry
Drives: Chevy Blazer
Most fluids should be changed after the break in period
Sent from my SM-G930W8 using Tapatalk
drperry is offline   Reply With Quote
Old 08-18-2018, 03:37 PM   #4
nancygrl
雪の玉
nancygrl's Avatar
Drives: '22 Z71 RST Silverado
I changed mine once I hit the 1500 mile break in period. It's easy to do and won't hurt to do it.
nancygrl is offline   Reply With Quote
Old 08-18-2018, 05:39 PM   #5
cmking26
Drives: 2018 Arctic Blue SS Recaro's
Definitely should be changed sooner than later from new. Mine had 5000 mi when I did it and quite a bit of sludge and shavings on the plug.
cmking26 is offline   Reply With Quote
Old 08-18-2018, 06:05 PM   #6
dpevans
Drives: 2024 Riverside Blue 2SS 1LE
Do it, you won't regret it.
dpevans is offline   Reply With Quote
Old 08-18-2018, 06:24 PM   #7
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Yes change it...with AC delco fluid.
Old 08-19-2018, 12:05 AM   #8
Opus13
Opus13
Opus13's Avatar
Drives: 2017 Camaro 1SS, Black
Did mine at around 1,500. The color was a little gray with some shiny particles mixed in.
Real easy to do.
"My entire life in one sentence:
It didn't go as hoped, but that's okay"
Opus ie. Berkeley Breathed.
Opus13 is offline   Reply With Quote
Old 08-19-2018, 02:21 AM   #9
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
doesnt matter if its limited slip. ask a gear shop. should be changed at 500 then again at 1000-1500
Old 08-19-2018, 11:21 AM   #10
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
Still have the original fluid in mine... 12k miles.... hmmmm
Old 08-19-2018, 12:28 PM   #11
dpevans
change it Avalonandi you will be shocked what comes out.
Old 08-19-2018, 01:17 PM   #12
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
Will have dealer change it at next oil change. I pay people to do this stuff now....old and gray....LOL
Will make sure they add the 88900330 AC Limited slip LUBE too....
Old 08-19-2018, 01:32 PM   #13
torqueaddict
Drives: Tesla M3 LR-AWD [Former 1SS owner]
As long as the correct oil is used, I can't see anything wrong with an early change.
In my case, I'm sticking to the manufacturer's recommended intervals for the tranny and diff. Track use would be the only reason I'd do them sooner. The exception was the engine, which I did around 1100 miles (currently at ~4800 miles).
torqueaddict is offline   Reply With Quote
Old 08-19-2018, 04:26 PM   #14
Doug kj6aco
Doug kj6aco's Avatar
Drives: 2017 1LT RS M6
Changed mine at 20,000 because in the morning when cold and turned out of my neighborhood I could near a slight noise.
After change with correct fluid no noise.
Doug kj6aco is offline   Reply With Quote
