![]() ![]() Drives: 2017 ZL1 Join Date: Jan 2017
Note: Upper control arm, upper/lower trailing arm bolts are 1 time use
Hey,
I was was swapping in BMR upper control arms today (have upper/lower trailing coming soon) and quickly found out the M12x1.75 bolts are 1 time use! Please use caution if you are replacing yours and order new bolts. I stretched 1 or two of them and call it quits. Going to hope dealer has them in stock tomorrow. Part # to order is: 11610908, 2x user per. If you were to replace all 3 parts on both sides you need 12 bolts.
Note: fyi the torque spec that is supplied of 81 ft/lbs is incorrect, do not use. BMR will hopefully update soon.
