![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1ss camaro Join Date: Feb 2016
MCS SUSPENSION SHOCKS
i guess these guys are the first to market with aftermarket shocks for the 6th gen camaro anybody used these before? pretty pricey but seem nice
http://motioncontrolsuspension.com/pricing/ Camaro 2016 > $2,750 $3,450 $4,400 $6,000
![]() Drives: 2017 1SS 1LE Join Date: Aug 2017
rotis has been running them on his STP car for a while now. MCS is good stuff.
www.facebook.com/1lap1le
2017 1SS 1LE - 663 whp/623 wtq Rotofab/Whipple/Kooks 2"/LT5 TB/LT4 Fueling/E85/MCS Coilovers/Ground Control/GOODAero/Apex Wheels/Race Louvers |
![]() ![]() ![]() ![]() ![]() Drives: 2017 1SS/1LE Join Date: Sep 2016
Brian Tyson on the east coast installed some. Not sure which version he added or the spring rates.
he said they manufacture complete units both front and rear 44mm main piston and 22mm diameter shaft. The od of the strut body is 52mm and the strut ears are wideneded to allow for wider wheel and tire packages. The rear are aluminum and also use 44mm diameter piston and they have a 16mm or 22mm shaft.
![]() Drives: 2019 ZL1 1LE Join Date: Sep 2010
yep, they are great. The strut ears are setup to provide more room between the strut body and the tire. I fit 315/30-18 on 11” wide front wheels under the stock SS fenders.
I won CAM at the Pro Finale, and won STP at the National Championships with the MCS setup last year. They have been rock solid and I’m running them at Nationals again this year in CAM. Swing by and take a look if you’re around. |
thanks! they put me in touch with martin at ar auto service and i guess he has a whole setup with camber plates and springs and other parts also
are you running just the replacement shocks/struts or a whole setup?
#7 |
MCS only makes the dampers. They are designed to be used with standard 2.25" or 2.5" race springs so you need to get plates, springs, and all the other bits. The Ground Control articulated weight jackers for the rear springs are super trick.
My car was the development platform for AR Auto and MCS to develop the setup, so Martin@AR knows exactly what is required. You pick spring rates, or you can go with their recommendation. My car is a serious business autocross machine, so the springs rates I'm using are probably higher than what you'd want if you are spending more time on the street. |
#8 |
oh ok gotcha yea cause i already have powell racing yyz springs and he was working with bilstein so not sure if its going to happen but i wanted just the replacement shocks not the whole kit
#9 |
so i guess these arent replacement shocks its pretty much a full coilover setup that runs like $4500 or so boo
#10 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
I would probably go with the DSSV ZL1 1LE upgrade option. Granted those are fixed, but if you are looking for performance first, that might be the better option.
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 |
#11 |
yea i agree i was just looking for a replacement shock option lol back to the drawing board
ill hit up koni and bilstein again at sema this year but probably same answer NO!
#12 | |
![]() Drives: 2015 Camaro 1SS Join Date: Dec 2017
I emailed Koni in April and this was their response.
#13 |
lol same thing they told me at sema 2017 ill ask them about at sema this year as well as bilstein...just crazy there is nothing as oem upgrade replacement other than gm lowering kit or dssv kit both from gm
#14 |
I think the DSSV is the way to go for shocks. I just wish GM offered some options for spring rates. A few options for street cars would be nice.
Current:
