Old 08-15-2018, 06:00 PM   #1
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
PIC6276B - Clunk Noise From Front Suspension At Low Speeds
Condition
Some customers may have a concern where they hear a clunk or rattle noise coming from the front of the vehicle when hitting bumps. This can typically be heard while driving at parking lot speeds and hitting imperfections or speed bumps in the road.
Cause
This noise may be caused by the front stabilizer bar end link nut(s) loosening up which may cause the stabilizer bar end link(s) to make a rattle noise. This can happen on either/both side(s) of the vehicle. This noise can easily be mistaken for a front strut and/or strut mount assembly noise.
Correction
Dealership technicians are to inspect the upper and lower stabilizer end link nuts for proper torque.
Note: To remove the end link nuts, first use an allen wrench or a hex socket to hold the internal shaft stationary. Then use a wrench to remove / reinstall the nut.
Front Stabilizer Link to Strut (upper) Attachment:
Remove the end link nut and discard it.
Replace it with a new nut (PN 11548382).
Tighten the nut to 89 foot pounds (120 Nm).
Front Stabilizer Link to Stabilizer Bar (lower) Attachment:
Remove end link nut and discard it.
Inspect and clean the stabilizer end link ball stud threads to make sure they are not damaged. Apply high temperature/high strength thread locker (PN 89021297) to the threads.
Replace the nut with a new one (PN 11548382).
Tighten the nut to 96 foot pounds (130 Nm).
Old 08-15-2018, 08:56 PM   #2
carguy55
carguy55's Avatar
The new nuts look good but will they work even with loctite
Old 08-15-2018, 10:54 PM   #3
camaro5
camaro5's Avatar
Drives: X-15 Velocipede
https://www.camaro6.com/forums/showthread.php?t=489428
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer
STANDARD DISCLAIMER
camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever,
whether express, implied, or statutory, including, but not limited to, any warranty of merchantability
or fitness for a particular purpose or any warranty that the contents of the information will be error-free.
camaro5 is offline   Reply With Quote
