08-15-2018, 01:33 PM | #1 |
Drives: C6 Corvette Join Date: Aug 2018
how effective are the SS hood vents?
How good are the stock SS hood vents at pulling heat out of the engine bay? Looking at them, it seems as if only 1/3 of the length is actually vent and the other 2/3 are decorative. Are there aftermarket ones that use the full size cutout for venting purposes?
08-15-2018, 01:41 PM | #2 |
Retired from Car mfrs....
Look at hexvents.com......I've had two sets, very high-quality alum Powder coat, not plastic
08-15-2018, 05:13 PM | #3 |
Lovin the growl...
Drives: 2018 2SS Join Date: Mar 2017
Hopefully very effective. But they are part of the gen 6 SS look that I absolutely love.
2018 2SS: Garnet Red, NPP, Kalahari interior, sky lid.
08-15-2018, 08:16 PM | #4 |
Drives: 2018 Camaro SS1 1LE Join Date: Feb 2017
Hexvents website lists vents for 2016-2018 but the pics are of an older model.
08-15-2018, 08:24 PM | #5 |
08-15-2018, 08:52 PM | #6 |
Drives: 2017 SS 1LE Join Date: Mar 2017
They worked when I hit 174, no hood buffering (is that a word?) , front end did not wander, or heat issues...
08-15-2018, 09:02 PM | #7 | |
08-15-2018, 09:34 PM | #8 | |
https://www.camaro6.com/forums/showthread.php?t=529024 |
08-15-2018, 10:38 PM | #9 |
Drives: 2017 Camaro 2SS, A8 Join Date: Aug 2017
It would be nice of they had a quick release for the rain guards to open the vents up completely.
08-15-2018, 11:36 PM | #10 |
Drives: 2019 2LT 2.0T M6 Riverside Blue Join Date: Jan 2018
08-16-2018, 12:48 AM | #11 | |
Drives: 2SS 1LE Join Date: Oct 2011
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
08-16-2018, 01:01 AM | #12 |
Drives: 17 SS 1LE Join Date: Dec 2015
It looks like the solid part is to guide air along the hood.
08-16-2018, 02:09 PM | #13 | |
Thanks for the responses.
Full disclosure: i'm looking at them to add vents to my C6 Corvette hood. The current trend to adding hood vents to the C6 Corvette is to use the 5th Gen Camaro center vent. I like the look of these twin smaller vents than the single middle one. The Corvette is a ground breather and sucks in outside air from under the car, so having escape vents at the hood allows for better airflow from underneath through the engine bay and out the top. The location of the twin vents at the sides of the hood line up better with the airflow path for the radiator than the center vent which due to its low hood is basically touching the intake manifold. Many automakers have for years used cosmetic pieces to enchane the look of vehicles. The Camaro vents are functional, but I'm curious HOW functional. Would it be better to just get some generic race vents (like the ones sold on hexvents.com)? But they are not nearly as attractive as the 6th Gen camaro vents. If the camaro vents are effecient for drawing out air, then they would fit perfect with the lines of the C6 vette, and still give it that factory look. Quote:
