Old 08-12-2018, 10:52 AM   #1
kwav8r
Flyin NOE
Drives: 2018 ZL1 (A10)
Borla 60608 Resonator Fitment - INSTALLED
Has anyone installed a Borla 60608 Resonator on a ZL1? If so were there any fitment issues? Having installed the 60606, I know there isn't a bunch of room to play with as I had to adjust the mid pipe to keep from coming into contact with a tunnel brace.
I know someone else on this forum installed one on an 6 Gen SS but I'm just not sure if there is a major underbody difference between an SS and ZL1.
Old 08-13-2018, 08:19 AM   #2
Jhunsberger
Jhunsberger's Avatar
Drives: 2017 Camaro 1SS M6 (SOLD)
Perhaps I am the SS guy you are referring to, here are pics of the 60608 resonator installed on my SS, with the 60606 and ATAK system, also using the NEP cat delete pipes.
Although not the best pics of the actual 60608, but you get the idea.
Stock: 416hp/427tq, 12.21 @ 116.80
Modified 02/2019: Whipple SC w/ 3.500 pulley, LT4 fueling, NW 103 TB, Roto-Fab Big Gulp, Kooks 2" jet coated, full Borla ATAK exhaust, DSS axles, Gforce driveshaft.
Tuned by EFX Tuning 688hp/632tq
Best 1/4 to date: 10.705 @ 131.92
Jhunsberger is offline   Reply With Quote
Old 08-13-2018, 11:31 AM   #3
bomariam1
Drives: 2018 ZL1, Cadillac ATS-V
ZL1 has a different part number.
140726 for Atak
140727 for S-type
Sent from my SM-N950F using Tapatalk
bomariam1 is offline   Reply With Quote
Old 08-13-2018, 01:09 PM   #4
Chris Edwards
Drives: 2017 ZL1
Did you try the cat delete before you added the restonators? How much difference did the resonators make? Can't imagine they would quiet things down much being so small.
Chris Edwards is offline   Reply With Quote
Old 08-13-2018, 01:34 PM   #5
Jhunsberger
Did the cat delete pipes 1st, and it was so loud and raspy, I did not like it at all. Then that led me to do the cat back Borla ATAK set-up. I believe the resonator helped with the raspiness, perhaps the mufflers help too. Borla said the resonator has ceramic packing, and that I should not have any over heating concerns.
Overall I am very happy with the sounds now and I would recommend the resonator from my own experience.
Old 08-13-2018, 09:31 PM   #6
kwav8r
Flyin NOE
Yep, you’re the guy! Thanks for posting the pics and giving your impression of them. Think my opinion is much like yours with respect to the cat delete- it’s just two raspy for me.
Judging from your pics I don’t think there’ll be any problem getting the resonator in my ZL1. Underside looks much the same (not surprising).
I’m still running the OEM suitcase (I like the stealth mode too much with the NPP) and waiting for the right exhaust note to come out. To me, deeper is better.
Again, thanks much
Old 09-02-2018, 08:30 AM   #7
kwav8r
Flyin NOE
OK, so got the Borla Resonator (60608) installed and I couldn’t be happier with it. After initially installing just the 60606 (secondary cat delete w/ X-pipe) the exhaust note was too raspy and loud for me especially at three quarters to WOT, I also wasn’t a fan of how loud it was on start.
The 60608 deletes the center (straight mid pipe) section and goes on as a single piece. While I was concerned about it fitting and making contact with the tunnel bracket toward the rear of the car it actually gave more clearance to the bracket and it takes the guess work out of which way to twist the mid pipes.
Exhaust note is definitely deeper, not as loud inside the car at 3/4 to WOT, but it’s still aggressive and you still getting some good exhaust pop when decelerating.
Overall couldn’t be happier. I’ll try to post a video in the next couple of days.
Old 09-02-2018, 04:18 PM   #8
1LE Red Dragon
Train Driver
Drives: 2018 Summit White ZL1 1LE
Awesome. Glad you got it on a good sale too.
2018 Camaro ZL1LE
/ / Katech TB // RotoFab Dry // Borla 60606 // ATI Super Damper / /
1LE Red Dragon is offline   Reply With Quote
Old 09-02-2018, 05:24 PM   #9
kwav8r
Flyin NOE
Old 09-02-2018, 06:20 PM   #10
1LE Red Dragon
Train Driver
I installed my 60606 yesterday.. It is a little rowdy in track mode... But I like it. Glad you like your new setup too.
2018 Camaro ZL1LE
Old 09-02-2018, 07:10 PM   #11
Chris Edwards
Drives: 2017 ZL1
Why not go with a Magnaflow 2 into 2 resonator? Heard they are even quieter and sound better.
Old 09-02-2018, 09:10 PM   #12
Stealth7
Drives: Gen V Viper GTS
When you are referring to "cat delet" pipes are you talking about the secondary cat resonators or the primary catalytic converters? Thanks
Stealth7 is offline   Reply With Quote
Old 09-02-2018, 09:34 PM   #13
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
Nice setup OP. Glad it worked out for you. My guess is this will go wild with the people who don't love the raspy sound of an uncorked LT4.
Old 09-03-2018, 11:53 AM   #14
kwav8r
Flyin NOE
Secondary cats are deleted, the primaries still sit inboard of the O2 sensors. The 60606 deletes those cats (pun intended). FWIW, some folks refer to the OEM secondaries as resonators but, when you look inside they definitely look like catalytic convertors (honeycomb material).
