What is the oem A8 ATF
What is the OEM automatic transmission fluid for A8 SS camaro? And what are other good brands/kinda of oils.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL-1 Join Date: Feb 2009
Read the manual, i believe its Dexron 6. Use GM or meets the equivalent. Stay away from the snake oil (Royal Purple).....
2012 Yukon XL Denali w/ 6.2 AWD |
Kevin
Drives: 2018 Callaway Camaro ZL1 1LE Join Date: Apr 2018
This is from the manual:
DEXRON-HP Automatic Transmission Fluid (GM Part No. 19331925, in Canada 19300537). If you really want the good stuff that GM uses for the transmission flush when some have problems with transmission shudder, use this. You will need enough to fill and drain a couple of times. It is expensive but the results are good. I changed to it in my A8 Z06 and couldn't be happier: Mobil 1 Synthetic LV ATF HP. It is approved and licensed by General Motors against DEXRON® HP ATF. It is warranty approved. There is nothing wrong with Royal Purple if it meets GM specs. |
![]() ![]() Drives: 2019 Shock ZL1 Join Date: Jan 2007
The original HP is not to be used. Mobil 1 LV HP is the only approved fluid for the 8L45/90.
From Super Chevy mag, April 2002: "Most of the weekend Settlemeire was meeting and greeting and quickly became known as simply "The Camaro Dude" (note, even his initials are SS)."
![]() ![]() ![]() Drives: 2016 Camaro 2SS Join Date: Apr 2017
Pretty sure this is the new part number 19353429
