Old 08-08-2018, 10:38 AM   #1
SSport16
SSport16's Avatar
A8 - Hesitation putting car into gear - Cold
Anyone having issues putting the car into D when the car is cold. Mine either hesitates before it "grabs" into gear or bucks. Does it probably 95% of the time when the car is cold. Reverse seems to be fine when I back out of my garage, even when the car is cold.
Old 08-23-2018, 01:12 PM   #2
gmw0181
gmw0181's Avatar
Drives: 2017 Camaro 2SS A8
Same on my 2017 SS2, the transmission fluid is cold. Let it warm up for a min.
gmw0181 is offline   Reply With Quote
Old 08-23-2018, 03:21 PM   #3
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Yes let it warm up a bit first...these cars get up to temp quick anyway.
Old 08-24-2018, 10:46 AM   #4
SSport16
SSport16's Avatar
I have let it warm up for a few mins, still does it then, not every time but a good portion of the times.
Old 11-19-2018, 02:02 AM   #5
SteevK
SteevK's Avatar
Drives: 2017 2SS Hyper blue A8 NPP MRC
What mode are you in? I find mine does it in Touring mode, while Sport mode does it less, if at all.
BTW: Manual doesn't say so, but if you turn car off in Track or Snow/Ice modes, it starts in Touring mode. Sport mode stays on when you start it...
2017 Hyper Blue 2SS 8A K&N Typhoon w/Spectre blue filter, Vitesse throttle control, 2019 Camaro twisty rims with blue lugs, Blue "SS" badges
SteevK is offline   Reply With Quote
Old 11-19-2018, 10:46 AM   #6
SSport16
SSport16's Avatar
I usually leave it in sport all the time, so it starts up in sport. I have tried different modes and makes no difference.
Old 06-17-2019, 09:18 PM   #7
Novice
Novice's Avatar
Drives: 2016 2SS Nightfall Gray
I have the same issue on my 16 2SS A8. Happens regardless of what mode. Family member had a 2016 GMC Sierra 1500 Denali w/ 6.2 with same issue (very low miles at the time) and got a new transmission under warranty back in late 16/early 17..
Novice is offline   Reply With Quote
