Old 08-06-2018, 11:49 PM   #1
Dvs510
Dvs510's Avatar
Drives: 2018 Camaro SS/1LE
Question about drop in filter
I’m sure this topics been covered numerous times already so my apologies in advance.. I was wondering if anyone has done just a k&n, aem, or any other brand drop in filter and had any noticeable sound or performance difference. I’ll eventualy do full cai. But until my wife cools down about how much I spent on car I’d like to keep my parts prices down
Dvs510 is offline   Reply With Quote
Old 08-07-2018, 12:59 AM   #2
JamesNoBrakes
JamesNoBrakes's Avatar
Drives: 2SS 1LE
Guaranteed to add 3231 miniature my-little ponies.
2018 2SS 1LE
2023 Colorado ZR2
2022 Stinger GT-line AWD
JamesNoBrakes is offline   Reply With Quote
Old 08-07-2018, 06:42 AM   #3
Gabhart
Gabhart's Avatar
Drives: 2018 Hyper Blue 1SS 1LE
I installed a K&N filter before moving to a GM Performance CAI and did not feel or hear a difference with the K&N.
Gabhart is offline   Reply With Quote
Old 08-07-2018, 07:02 AM   #4
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
The stock airbox is sized for the LT4. Don’t waste your money.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph
Old 08-07-2018, 10:49 AM   #5
zx9rmal
zx9rmal's Avatar
Drives: '20 ZL1 M6
I installed a K&N. Went back to OEM, which I think feels ever so slightly more linear in throttle response.
Mal
Ft. Lauderdale, FL
'20 Camaro ZL1 M6
'22 Kawasaki ZX-14R
zx9rmal is offline   Reply With Quote
Old 08-07-2018, 10:53 AM   #6
Bad Anvil Garage
Bad Anvil Garage's Avatar
Drives: 2000 GMPPSV SS & 2020 2SS
Believe it or not, GM engineers are pretty good at what they do...
Bad Anvil Garage is offline   Reply With Quote
Old 08-07-2018, 11:58 AM   #7
D3adpool
D3adpool's Avatar
Drives: Garnet Red 2018 SS 1LE "Deadpool"
I know you're holding off to make the wifey happy, but I'd just use the stock filter until you are ready to drop $$$ on a complete CIA.
I'd suggest Rotofab's CIA when you're ready to do it.
Hope this helps!
D3adpool is offline   Reply With Quote
Old 08-07-2018, 02:04 PM   #8
nasbagoat
Drives: 17 SW 1LE
pull the foam insert out of the foam tube
nasbagoat is offline   Reply With Quote
Old 08-07-2018, 04:11 PM   #9
Pollock
LT4 M6
Pollock's Avatar
Drives: 2018 ZL1 1LE
happy wife happy life!
Pollock is offline   Reply With Quote
Old 08-07-2018, 10:16 PM   #10
JonD
JonD's Avatar
Drives: 2018 SS 1LE
After talking to a shop & long time known tuner unless you plan on getting inside the motor to do cam & heads. OEM airbox will more then enough so I’m not spending the cash on a CAI
🌽 Sauced, 2018 SS 1LE - 123mph @ 5,000 DA
ARH 2”x3” FULL System, Pray Ported MSD Intake Manifold, Pray Ported GM 95mm TB, RotoFab CAI, DsX e85 Kit, MightyMouse Catch Can, NicD Tune
https://instagram.com/corn_sauced?ut...d=o0ako89uurwl
JonD is offline   Reply With Quote
Old 08-07-2018, 11:10 PM   #11
Whitespeed
Drives: 2018 1SS 1LE & 1973 Datsun 240Z
Hopefully not going too far off topic, but how is a so called "cold air intake" providing air that's any cooler than the OEM box? They all draw air from the same place at the front of the car. Its not like the old days when someone would just stick a filter right on the throttle body where it would actually be drawing hot air from the engine bay.
Whitespeed is offline   Reply With Quote
Old 08-08-2018, 01:05 AM   #12
JamesNoBrakes
Drives: 2SS 1LE
Well, it takes your cold hard cash.
2018 2SS 1LE
2023 Colorado ZR2
