Old 08-05-2018, 05:12 PM   #1
Drsagacity
Drsagacity's Avatar
Directions for catch can with Magnuson?
Anyone have a Mishimoto catch can with the Maggie? Pictures or helpful guidance would be appreciated.
776whp/745wtq (12psi)
2018 Corvette Z06 vert- Black
To be tuned by JRE Racing
TBD performance
Old 08-06-2018, 08:09 AM   #2
Jhunsberger
Jhunsberger's Avatar
Drives: 2017 Camaro 1SS M6 (SOLD)
Have one with a Whipple.....hooked up same as before.
Stock: 416hp/427tq, 12.21 @ 116.80
Modified 02/2019: Whipple SC w/ 3.500 pulley, LT4 fueling, NW 103 TB, Roto-Fab Big Gulp, Kooks 2" jet coated, full Borla ATAK exhaust, DSS axles, Gforce driveshaft.
Tuned by EFX Tuning 688hp/632tq
Best 1/4 to date: 10.705 @ 131.92
Jhunsberger is offline   Reply With Quote
Old 08-14-2018, 07:25 PM   #3
Drsagacity
Drsagacity's Avatar
I will take some pictures. The hoses that came with the kit obviously didn't work, but I like the way we set it up. It is in front of the engine bay and really easy to access. Will take pictures in the next couple days.
TBD performance
Old 08-14-2018, 07:49 PM   #4
Drsagacity
Drsagacity's Avatar
Sitting at my daughters soccer practice and grabbed a few pictures.
TBD performance
Old 08-14-2018, 09:26 PM   #5
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
You ideally need a different catch can for a FI setup...it needs to have a check valve with a breather so it can vent crank case pressure to atmosphere under boost. If you don't, you will start pushing seals out of the engine at higher boost levels.
Old 08-15-2018, 01:07 AM   #6
Drsagacity
Drsagacity's Avatar
I have a breather on the other side replacing the oil cap. What does that do?
TBD performance
Old 08-15-2018, 08:09 AM   #7
KingLT1
KingLT1's Avatar
If it's a breather with a check valve then you are good.
Old 08-15-2018, 01:09 PM   #8
Drsagacity
Drsagacity's Avatar
Yep. It replaces the oil cap.
TBD performance
Old 08-20-2018, 06:24 AM   #9
Jhunsberger
What breather with check valve do you have? I have a mishimoto catch can with a whipple and i feel i need to upgrade the can or add the breather with check valve.
Old 08-20-2018, 07:13 AM   #10
Drsagacity
Drsagacity's Avatar
https://jannettyracing.com/products/...2015-camaro-ss
Old 08-20-2018, 07:16 AM   #11
L78toLT1
L78toLT1's Avatar
I have a Metco breather. Got it from Ted Jannetty
Baby Blue
Old 05-22-2021, 04:51 PM   #12
ShortBlock
Camaros of NorthWest Ohio
ShortBlock's Avatar
Drives: 2012 LS
The 2 hoses on the catch can were do they run to?
The hose from the valley goes to the intake behind the tb on the Maggie so u can't use that one.
2012 ls 20in rims,cai,oil catch can,throttle body spacer,billet grill,axle back exhaust,vitesse throttle control,red oracle headlight halos, red oracle afterburner taillights,blacked out windows,oem strutt tower brace polished and painted
ShortBlock is offline   Reply With Quote
