Old 08-04-2018, 11:14 PM   #1
Corvette_Mike
Corvette_Mike's Avatar
Drives: 2018 Camaro SS
How does my LT1 motor go from V8 to V4
I'm trying to learn about my Camaro. One question I have is how my LT1 goes from V8 to V4?
Thank you for your replies
Corvette_Mike is offline   Reply With Quote
Old 08-05-2018, 06:52 AM   #2
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
In a nutshell: The lifters stop lifting and the fuel is cut off to 4 cylinders.
Here's a couple vids...
Old 08-05-2018, 09:41 AM   #3
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Disable it...it's the worst technology GM ever came up with for such marginal fuel savings.
Old 08-06-2018, 05:25 PM   #4
Corvette_Mike
I see the valves are not opening. Are the lifters shutting down for v4 mode?
Old 08-06-2018, 06:14 PM   #5
cmitchell17
Drives: 17 2SS, 8L90, Cam, Heads, E85
What about the air noise it makes when it engages 4 cyl at low speeds? I assume this is when there is a certain volume of air inside the intake manifold and then you cut half the displacement and you get a air backfire out of the intake?
But it almost sounds like the noise is coming from the exhaust? Either way what's weird is that you never hear the noise when it switches on the highway. I'm not even sure looking at the tables in HP tuners how AFM is engaged? Weather it is torque based or not? There is no scaler table controlling engagement, only hysteresis and temp settings?
cmitchell17 is offline   Reply With Quote
