Old 08-04-2018, 03:25 PM   #1
Calubi
Drives: 2017 1SS 1LE
Compression test procedure?
Quick question on compression testing these LT1 motors. Is there a fuel pump fuse or harness that needs to be disconnected before cranking, or is it sufficient to just hold the accelerator pedal?
2017 Camaro 1SS 1LE - Stock for now
2015 VW Golf R DSG - GIAC ECU/TCU tune
Calubi is offline   Reply With Quote
Old 08-04-2018, 05:14 PM   #2
scooter k
Drives: ex-wife's car
Just hold the accelerator to the floor.
scooter k is offline   Reply With Quote
Old 08-04-2018, 06:14 PM   #3
laynlo15
Drives: 2022 Lt1 A10
That deactivates the injectors so they do spray fuel into the cylinder
Old 08-04-2018, 06:42 PM   #4
Calubi
Thanks guys!
Old 08-05-2018, 02:52 PM   #5
Calubi
Damn, how are you guys getting to the passenger front plugs? No matter how I mess with the overflow tank and coolant lines/wire harnesses, I cannot get my hands in there enough to pull the plug wires off, let alone getting a socket wrench in there for the plug!
Old 08-05-2018, 04:37 PM   #6
SanDMaN2091
SanDMaN2091's Avatar
Drives: 2016 Camaro SS A8 NPP
Crimp the lines and pull the coolant tank. It's only one nut.
DMS Flex Fuel-E85
HPTuners Ngauge
Roto Fab CAI,
LPE Ported/Polished 95mm LT5Throttle Body,
PRAY Ported MSD Intake Manifold,
SP Coated TSP 1 7/8" Catlless Longtubes
Hooker BlackHeart Cat-Back,
Mishimoto Catch Can (Which always has some nasty in it)
Instagram@Weapon_6
SanDMaN2091 is offline   Reply With Quote
Old 08-05-2018, 05:31 PM   #7
Dubchitts
Dubchitts's Avatar
Drives: '17 Red hot 2ss, 16 Focus RS
This is 10x easier than trying to sqeeze and contort your hand lol
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC
Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance
Dubchitts is offline   Reply With Quote
Old 08-05-2018, 05:37 PM   #8
Calubi
Ugh, I was hoping to not have to pull the overflow tank.
So I take it people aren't doing compression tests on hot engines? I'd hate to risk leaking hot coolant trying to get that tank out.
