Old 08-04-2018, 12:21 AM   #1
1018 Video
Drives: 2017 Camaro 2.0T A8
Throwing a couple codes. Need help deciphering
I threw a code for p0236 which was boost sensor not operating withing range.
And a code for p2227 which was the barometric sensor not operating within range.
After it threw these codes, the car went into limp mode and I had a misfire. The misfire was VERY consistent at idle but seemed to clear up above 3500 rpm.
I cleared the codes, and the car feels just as strong as before, but still with the misfire. Plugs look fine btw
Only a slightly modded I4-A8
Check out 1018 Video on YouTube!
1018 Video is offline   Reply With Quote
Old 08-04-2018, 07:12 AM   #2
Thandel
ATS 2.0T
Drives: 2013 Cadillac ATS
Any mods?
Could be a bad coil.
Could be a bad sensor iat on the cold side pipe, could be a bad maf.
Thandel is offline   Reply With Quote
Old 08-04-2018, 09:42 AM   #3
cooper1965
Coopers Camaro
cooper1965's Avatar
Drives: 18 Flex Fuel LTG
Looks to me like P0236 with P2227 only, is altitude VS barometric pressure not in table range. There in Arkansas, you should see something around 94-104 kPa. Unless your running up around Signal Hill. The number should lower as you climb altitude.
Flex Fuel tuned by me using HPT-:-
---My Build Thread---
-----My IG PAGe-----
Old 08-04-2018, 01:23 PM   #4
Jason@JacFab
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
Check the sensor connectors. Sometimes after unplugging and reconnecting they seem to not get a good seat, and you have to unplug and replug/wiggle, etc.
Have you already tried to splice in your arming switch, etc into some sensor and perhaps messed up the wiring somehow, etc?
Old 08-04-2018, 05:20 PM   #5
1018 Video
No I never got started on the nitrous wiring. Was racing a ls1 transam and it just went into limp mode
