Old 07-31-2018, 06:06 PM   #1
ajp
50th Anniversary Vert
ajp's Avatar
Drives: Camaro 2017 50th Anniversary
Borla S Type 11925 and 60610 mouse squeek
Anyone else with the same combo get this sound? Also happens when driving (30-40 mph).
I'm on my 3rd X Pipe from Borla, with no resolution, I have racked up $450 in installation costs.
Is this what I should expect? I'm kinda at the end of my rope.
ajp is offline   Reply With Quote
Old 07-31-2018, 06:34 PM   #2
stangs024
Drives: 2018 camaro ss
Forgive me if this is a dumb question but if you hear that when switching engine sound from stealth to sport, wouldn't that be the NPP valve(s) in the muffler and not the x-pipe??
stangs024 is offline   Reply With Quote
Old 07-31-2018, 08:44 PM   #3
appleman22
Drives: 2017 1ss 1le
What does squeaky npp valves have to do
With the x pipe????
appleman22 is offline   Reply With Quote
Old 08-01-2018, 01:12 PM   #4
ajp
ajp's Avatar
With the x pipe????
Are you saying switching between Stealth and Sport is open/closing the valves closest to the exhaust tips and not the valves on the X-Pipe?
Old 08-01-2018, 01:26 PM   #5
grampa_ss
grampa_ss's Avatar
I'll say it. Yes. The AFM valves won't close or move at idle. But the NPP valves at the exhaust tip will open and close. Try pulling fuse 51. The prevents the NPP valves from closing.
Old 08-01-2018, 01:50 PM   #6
coruiz
Drives: 2018 Camaro 2SS Hyper Blue
My stock NPP exhaust does the same sound, It's definitely the NPP valve opening and closing.
Perhaps some WD40 or any other type of lubricant may help?
2018 Camaro 2SS
| Hyper Blue Metallic | A8 | NPP | MRC | NAV | HUD | ATAK |
coruiz is offline   Reply With Quote
Old 08-10-2018, 03:19 PM   #7
ajp
ajp's Avatar
Borla sent me replacement exhaust tips.
Issue resolved. Borla warranty and customer service was excellent. Their reputation is well deserved.
Old 11-07-2018, 09:01 AM   #8
ajp
ajp's Avatar
OK - so the mouse squeak is back after 3 months-ish.
Is this expected/normal?
Old 11-07-2018, 10:15 AM   #9
staples87
Drives: 2017 Camaro ZL1
Sounds like the NPP valve - It's constantly opening and closing. I'd recommend trying a fuse pull to leave the valve constantly open for a couple days and see if you still have the squeak.
staples87 is offline   Reply With Quote
Old 11-07-2018, 10:38 AM   #10
ajp
ajp's Avatar
Its easy to replicate, switching from Track/sport to touring causing the noise.
Old 11-07-2018, 12:22 PM   #11
Whocares05050
Drives: 2018 Camaro SS 1LE
Go lay under the rear bumper and have a buddy switch thr settings. Its the valve motors. Replace them or pull the fuse thats your options
Whocares05050 is offline   Reply With Quote
Old 11-07-2018, 03:08 PM   #12
staples87
It's the valves then. They either wear and make noise or they may be oiled from the manufacture to quiet the movement and after a while the oil dissipates and makes sound of the valves more pronounced.
Seems like they could use a beefier valve.
