Old 07-31-2018, 02:31 PM   #1
parish8
Drives: 17 SS a8
People running the cpr or weapon x low side fuel system?
I pretty much copied the cpr set up but with 2 aux pumps.
Is anyone having issues with fuel sloching and uncovering the pick up? I start running into issues at 3/4 of a tank. Under certain conditions I see my fuel pressure drop to nearly nothing. The other day I did a 45mph roll race but with a very abrupt hit (brake boost to ~10psi and then let it rip) and lost all fuel pressure. From a more gentle roll even from a lower speed it flows enough fuel for 18+psi. Seems like the fuel is doing a big flip with the air briefly and uncovering the pick up.
I am 99% sure it isn’t any form of vapor lock.
I have checked the fuel transfer function and it is constantly pushing fuel to the passenger side as it should.
Any ideas? I am thinking about just doing a fuel cell in the drivers rear 1/4 area and feeding the port injection out of that or some kind of a surge tank set up.
Old 07-31-2018, 04:05 PM   #2
Turbo_RORO
Turbo_RORO's Avatar
Drives: Camaro 17 SS
I have a similar setup to yours but only with a single Bosch 044. My setup has the setup in the rear/lowest point. I have run the system with the low fuel light on and have not had an issue with fuel pressure. I am doing a surge tank for my port injection, but it is because I'm having an issue with leaking.
Turbo_RORO is offline   Reply With Quote
Old 07-31-2018, 04:18 PM   #3
parish8
Drives: 17 SS a8
It is just a drilled and tapped hole with a fitting threaded into it? No pick up sock or anything like that?
Old 07-31-2018, 06:56 PM   #4
Turbo_RORO
Turbo_RORO's Avatar
Drilled and taped. I don't have a screen. I do have a pre and post filter though. I'm building a surge tank, but that's to address a issue with leaking.
Old 08-01-2018, 12:19 PM   #5
Perdieu
Perdieu's Avatar
Drives: 2017 Nightfall Grey Auto 2SS
drilled and bulkhead fittings used no issues that we've seen on the dyno or on the street
Perdieu is offline   Reply With Quote
Old 08-01-2018, 01:16 PM   #6
Turbo_RORO
Turbo_RORO's Avatar
What epoxy is that?
Old 08-02-2018, 09:25 AM   #7
Perdieu
Perdieu's Avatar
Originally Posted by Turbo_RORO View Post
What epoxy is that?
Seal-All Contact Adhesive and Sealant
Old 08-02-2018, 11:09 AM   #8
Turbo_RORO
Turbo_RORO's Avatar
Thanks bro.
