Old 07-29-2018, 12:09 PM   #1
Clin5910
Drives: 2016 2ss, whipple supercharged
Need help, coolant temp gauge not working
So as the title says the coolant temp gauge randomly stopped working today and the fan will run full blast. Car runs fine with no cel. Ideas?
Clin5910 is offline   Reply With Quote
Old 07-29-2018, 05:08 PM   #2
Clin5910
I’m thinking it’s the coolant temp sensor. Still blows hot air in the car so I do t think it’s the thermostat. Can’t get a part till at least tomorrow as the parts stores near me are all closed, so I’ll find out for sure when I get a new sensor and see if that does the trick.
Any other ideas on what it could be?
Old 07-29-2018, 05:35 PM   #3
HighIron
Drives: 2024 2SS Summit White
Off the top of my head I'd say the sensor too, since the PCM "sees" an erroneous coolant temp parameter input and runs the fans as a fail-safe.
If it were your dash indicator you wouldn't get a reading but as far as the PCM was concerned, everything is fine....unless, that parameter input is a direct function of the gauge itself...but I doubt that.
HighIron is offline   Reply With Quote
Old 07-30-2018, 01:04 PM   #4
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
Warranty?
Old 07-30-2018, 03:04 PM   #5
ctrlz
Hook up a scan tool that lets you read different sensors. Coolant temp is pretty basic.
I agree with others, that it is likely a sensor failure. These are typically $10 parts. getting access to replace it may be the bigger problem. This is definitely covered by warranty.
Old 07-30-2018, 04:50 PM   #6
Jeb114
Jeb114's Avatar
Drives: 2021 300
warranty.
Jeb114 is offline   Reply With Quote
Old 07-30-2018, 06:28 PM   #7
Clin5910
Sorry guys but I probably should’ve mentioned that I’ve been running a whipple for the past two weeks after getting it tuned by a reputable shop. Had no problems since I got the tune dialed in up to now. Replaced the sensor and am about to take it for a drive and see if the problem clears up.
Ps the sensor was a pita to change without removing the air box
Old 07-30-2018, 07:33 PM   #8
Clin5910
So just did a little drive around the block after changing the sensor but same thing is still going on. Unless it’s the connector and not the sensor I’m not sure what else could be causing this. I checked the wires and they look in good shape.
Anyways I’ve contacted my tuner and I’ll see what he has to say but any help would be greatly appreciated.
Old 07-31-2018, 02:32 PM   #9
Sledgehammer70
Lethal Camaro
Sledgehammer70's Avatar
Drives: 16 2SS, 71 Std, Suburban RTS
Small known fact, not one of the coolant gauges in our cars seem to work properly. They never read the actual temps.
Sledgehammer70 is offline   Reply With Quote
Old 07-31-2018, 06:37 PM   #10
ctrlz
I would check with tuner to make sure ECM flash was done correctly. These units change the fan parameters to come on at higher speed earlier. You also get a new thermostat with the installation kit.
Old 10-10-2018, 06:15 PM   #11
Randall08
Drives: 2016 Camaro RS
Did you ever figure out the issue. I’m having the same problem
Randall08 is offline   Reply With Quote
Old 03-27-2019, 04:14 PM   #12
SPreston2001
SPreston2001's Avatar
Drives: 2017 Camaro 1SS
Mines is having this SAME exact problem. Fan runs on FULL BLAST sounds like a fighter jet and the temp gauge doesn't move (stays at 160). Took it to the dealership, bingo temp sensor was shot. Confirmed by the tech the car runs the fans full blast to protect against overheating since the car cant read the temp.
2017 Camaro SS, Garnet Red, 20” Bronze Chrome MMR ZL1 Reps
SPreston2001 is offline   Reply With Quote
Old 05-14-2019, 01:12 PM   #13
KelvinnDC
Drives: 2016 V6 Summit White/Adrenaline Red
Anyone figure out the issue??
KelvinnDC is offline   Reply With Quote
Old 10-29-2019, 05:27 PM   #14
TatsuSensei
TatsuSensei's Avatar
Drives: 2016 RS Hyper Blue
Just had to order a coolant sensor as noone in Georgia has it in stock. Will replace and hopefully it will be this simple. Same symptoms. No reading and full blast fans.
TatsuSensei is offline   Reply With Quote
