![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL-1 Join Date: Feb 2009
Is our X-Pipe in the wrong location?
Background: I had a 2005 GTO which I installed an x pipe on in place of a resonator (near the back of the transmission) and then put Magnaflows on where the the OEM mufflers were. All other OEM piping was left in place.
It had a very exotic sound, a higher note that really screamed at high rpms. Had a touch of drone at 2300-2400. I loved the sound, many others found it like the V8 Ferraris and Maserati's. Fast forward I have an SS. Getting the itch to head/cam it. When I look at the pics our X pipe is WAAY back in the system. My engine gurus say you want the x-pipe closer to the cylinder banks to even out the pulses for better scavenging. I agree, makes sense. There is NO way I am putting headers on my car. Our C6 actually has a dam good exhaust manifold tri-y.... Has anyone moved their x-pipe forward?
2012 Yukon XL Denali w/ 6.2 AWD |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Aug 2013
C6s dont have tri y manifolds
Who Needs to KNOW?
Engineers > bench racers.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
Yes, the 6th gen X-pipe is in the wrong place. When I put on the full ARH catless headers I ended up with 2 x-pipes as ARH didnt realize GM put the x-pipe at the rear.
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD |
Who Needs to KNOW?
Did you dyno before and after to reach that conclusion ?
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 14 Silverado LTZ Z71, 16 Camaro SS Join Date: Nov 2009
I’ve read that it’s better closer to the headers typically
But then again GM put it near the rear for a reason. And they know what that engine likes and have more hours into testing than any exhaust company out there A quality same day dyno test would be interesting. The difference is probably minor Oh and some of the corvette systems feature two x pipes as well. Thought that was interesting |
#7 |
![]() ![]() ![]() ![]() ![]() Drives: 2017 1SS/1LE Join Date: Sep 2016
I'm not exactly sure that they "didn't realize it"... I mean, in order to design their unit, they had to remove the stock exhaust from the car...
#8 |
![]() Drives: 16 ngm ss Join Date: Jan 2017
#9 | |
If you want, Ca6 is a Camaro.
#10 |
Nitpick all you want, we have the best oem manifolds.
In our Ca6..... Getting back to my original question has anyone moved their x pipe and what did it sound like.....
#11 |
![]() Drives: Chevrolet Camaro SS Join Date: Mar 2015
Per Dr. Gas, the originator of the X pipes states that the X is to be mounted as far forward as possible. Most factory systems are more a compromise for fitment than 'knowing what they're doing'. One of the other things that supports that is because the current vehicle is fuel injected. X pipes, H pipes and the merge cone work move effective on a carburated engine, think of it as an exhaust plenum chamber.
When placed properly and sized for the engine output it will increase HP due to its scavenging effects. Just like doing a 4-7 swap, changing duration between cam lobes based on intake manifold runner length, a proper X design can change the cam requirements. When done right the X can and will change the exhaust note to a higher pitch at WOT @ 4k RPM and higher. Back when the #4 Kodak Lumina driven by Erie Irvan first appeared at Daytona, you knew when he was coming and the sound grabbed your attention the first time you heard it. In OEM use, it does change the sound a bit, especially Vs an H pipe, but it is poorly placed to be effectively useful for additional HP. The general census is even a poorly played X pipe is still better than none. |
#12 |
Looking under the car I see no reason why they couldn’t have easily had it more forward. If it showed a measurable power gain I would think gm would have done it
But who knows I’d like to see a good dyno test |
#13 |
![]() Drives: 2018 Camaro SS Join Date: Sep 2009
GM also crushed the pipes in front of the muffler and varied the diameter of the pipes throughout the system. It’s tough for me to accept thats what the engine likes. Other things, clearly not performance related, are at play here.
#14 |
![]() Drives: 2017 2SS M6 FIFTY @51fifft Join Date: May 2017
The crushed pipes don't affect it.
