Old 07-27-2018, 10:36 AM   #1
modestech
modestech's Avatar
Drives: Hyper Blue 2016 1LT V6
V6 Drag Tips
I know at least one V8 owner will answer "get a V8", but that would change my class in the event.
I'm going to a drag event at Texas Motor Speedway this evening with friends to race my lowly V6. I have almost zero experience in this event - a street race style informal evening of drag racing by classes. I'd like to get tips on launch and best performance.
I have a 2016 Hyper Blue V6 (non RS, Bone Stock) - 8 SPEED AUTO - will be using stock tires, NO slicks or drag radials.
Any suggestions, tips or tricks?
Is it worth putting higher octane fuel in the V6? (specs are for just 87 octane)
modestech is offline   Reply With Quote
Old 07-27-2018, 11:28 AM   #2
JT58
Drives: Former 2016 Camaro 1LT
If they have the solution to do a burn out to make your tires sticky I would do that first. At the line I would hold the brake and push the gas pedal to rev it to about 1200-1500 RPM- or somewhere off idle. When the light turns green let go of the brake and mash the gas, let the engine and trans do the rest. You could shift manually but I would think the auto doing the shifting would be faster.
2006 C6 Corvette Manual, 2019 Silverado, 1997 Jeep Wrangler
JT58 is offline   Reply With Quote
Old 07-27-2018, 11:50 AM   #3
HackSaw
HackSaw's Avatar
Drives: 2017 Camaro SS
Do not wait for the green light. Leave on the 2nd yellow. Does your V6 spin the tires alot when you floor it from a stop on the street? If not dont bother trying a burnout and dont drive thru the water box.
HackSaw is offline   Reply With Quote
Old 07-27-2018, 11:58 AM   #4
PoorMansCamaro
PoorMansCamaro's Avatar
Drives: Really Slow
bring an air pump. reduce your tire pressure to about 24-26
Old 07-27-2018, 12:04 PM   #5
HackSaw
HackSaw's Avatar
I was going to bring up tire pressure but with a 6 cylinder wasnt sure lower rears was needed
Old 07-27-2018, 12:24 PM   #6
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
You have to experiment.... there is no set one way. Some crs like to be flashed, some like to be foot brakes, you have to play with tire pressure.
Try foot braking it up to stall speed... try flashing it off idle, and see which one performs better. Dont manually shift
And get a v8
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock
800 SAE rwhp. 9.4 @ 145 mph.
Old 07-27-2018, 12:58 PM   #7
KMPrenger
KMPrenger's Avatar
Lower rear tire pressure.
Add pressure to fronts.
Avoid water box.
No burn off, but do a quick spin to clean them off if you can.
Stage shallow
Start off the line at idle or just a hair over idle. Left foot on brake, right on gas. "Flash" the throttle by gassing as you lift off the brake.
Do the last part above after the last yellow lights up, but before you see green.
Good luck.
Old 07-27-2018, 01:00 PM   #8
PoorMansCamaro
Drives: Really Slow
Not sure what the number of cylinders has to do with physics. did lowering tire pressure help the v8's of old, that were pushing 300hp? I think so.
Old 07-27-2018, 01:03 PM   #9
modestech
modestech's Avatar
V6 Drag
Thanks for the replies. I left home without the air pump this morning. If someone else has one I'll do that.
Any opinions on octane?
My car doesn't spin a ton off the line from a stop - but not sure I've tried that without any traction control on. We'll have an hour of practice earlier in the evening. I'll try some different options. Two I want to try for sure is just flooring it in sport - tc on and off - and also holding with brakes and 2-3k rpm, maybe tc on and off.
Old 07-27-2018, 01:05 PM   #10
PoorMansCamaro
Drives: Really Slow
you want to keep all the nannies off. also, keep the ac off.
stick with premium octane.
Old 07-27-2018, 01:33 PM   #11
modestech
modestech's Avatar
Y'all tellin' me to run around with the AC off on a Texas summer night? I had anticipated that. I'll be turning it back on after the run though.
I was going to press and hold traction control to turn both settings off. : )
Old 07-27-2018, 01:35 PM   #12
PoorMansCamaro
Drives: Really Slow
trust me, I know the struggle with drag racing in the heat, living out here in vegas.
Old 07-27-2018, 01:43 PM   #13
modestech
modestech's Avatar
The heat should hurt the turbo cars more than me though.
Old 07-27-2018, 01:47 PM   #14
PoorMansCamaro
Drives: Really Slow
actually, that's the opposite. the heat affects FI cars less than NA cars.
