Old 07-26-2018, 12:09 PM   #1
rburke76
Drives: garnet red
Problem? or not?
LT 2017 Camaro. 4400 miles, brought brand new...runs great, never have any problems...last week noticed while car is in idle, car either shudders or shakes a little bit while its in park, then when I put it in gear it drives great, no problems....is it me? or not something to worry about?
rburke76 is offline   Reply With Quote
Old 07-26-2018, 12:14 PM   #2
PNYKLR2
PNYKLR2's Avatar
Drives: 2017 Camaro 1SS Convertible
Most likely nothing. My SS does it too. Some cars are more noticeable than others. Never hurts to check with the dealer since your still under factory warranty. You may have better luck posting this in the Engine sub-forum. You could also do a forum search by clicking the Search button toward the top right of whatever sub-forum your in and search for "Shudder or shake"
17' Camaro 1SS Vert - Plastidip for 50 Hp gain.
PNYKLR2 is offline   Reply With Quote
Old 07-26-2018, 12:15 PM   #3
ctrlz
This could be something as simple as the A/C compressor clutch engaging and the car compensating for the added load.
If you are not getting an error message or experiencing drivability issues I would say this is nothing.
Old 07-26-2018, 01:46 PM   #4
iarepeyton
iarepeyton's Avatar
Drives: 2016 Camaro 1LT V6
Pretty sure it's normal. Mine does it and my friend's does it. It's not like a big cam shaking the car but more like a vibration. The car is definitely designed for you to feel the engine, but tbh I wish it shook more
iarepeyton is offline   Reply With Quote
Old 07-27-2018, 02:08 AM   #5
protovack
Drives: 2019 2LT 2.0T M6 Riverside Blue
Has it had its first oil change yet?
Mine started shaking a bit in the front end around 2000 miles, then I changed the oil and it went away.
protovack is offline   Reply With Quote
Old 07-27-2018, 08:36 AM   #6
Camaro_QC
Camaro_QC's Avatar
Drives: 08 Tiburon GS, 2018 Camaro 2.0T
If you have the I4, it will shake a little more than other engines. It is well known that I4 engines are not as well balanced as a V6 ou V8 (physics involved).
2018 Camaro LS | 6 spd | 2.0L turbo | Nightfall Grey | RS package | Technology Package.
Order WDGHKX
1100 - 5/08/2018 | 3800 - 6/18/2018
2000 - 5/09/2018 | 4200 - 6/21/2018
3000 - 5/28/2018 | 5000 - 6/27/2018
6000 - 6/29/2018
Camaro_QC is offline   Reply With Quote
