Camaro drives without key fob!
So this is embarrassing to share but hopefully I can help someone from doing what I did.
I drove the car an hour away to do laps for charity at Texas Motor Speedway. Got to the track, shut the car off while checking in and waiting to go to the track and low and behold when I went to start the car I got a message on the display, "No Key Fob Detected." Somewhere between moving cars in the garage and driveway at home, I set the key fob in the garage thinking it was the key to the Malibu that I had to move to get the Camaro out. It was the Camaro key. The key fobs are identical, even had the exact same dealer key chains on them so it was an easy mistake to make. The car drove all the way to the track and I never got a warning or anything. I called OnStar and all they could do was offer to tow me. Seems like a flaw in the design but I actually had three other people tell me that day while I waited for my key to be delivered (thanks dad, still saving my butt at 43 years old) that they have done the same thing. The Camaro fobs no longer have a keychain and the Malibu fobs do to keep me straight and from ever doing this again. I hope this helps keep someone else from making this mistake. Embarrassing
Stirling
![]() Drives: 2017 Red Hot ZL1 M6 Join Date: Jan 2017
As i've always said, Keyless start is the stupidest modern feature of any car that has it. Between this and exiting the car without the key and having it honk at me, to no place to put it if you don't keep it in your pocket. I would value key ignitions coming back.
![]() Drives: 2017 Camaro 1LT Convertible Auto V6 Join Date: Jul 2017
I knew this would happen
Should have started a new thread on this issue because its hard to find my post, but check it out Page #6 post #80 My friends 2017 Mustang will not move out of Park if the FOB is not inside the car, stupid flaw on Chevy's part ![]() https://www.camaro6.com/forums/showt...=448599&page=6 Last edited by somedude; 07-26-2018 at 02:24 AM. |
#4 | |
![]() ![]() ![]() ![]() ![]() Drives: Crush ZLE M6 | 2000 Corvette FRC Join Date: Jun 2010
![]() Drives: 2017 Camaro Convertible SS Fifty Join Date: May 2018
I have many concerns with this.
Heck, someone could simply jump in the car if you are outside the vehicle, say in the trunk, or maybe just barely walking away, open the door and drive off. I do not see any safe guards to prevent this.
2017 Camaro SS FIFTY Convertible
![]() ![]() Drives: 18 zl1 Join Date: Aug 2017
I've had 4 cars, including this one that does the same thing. you can crank the car, but once cranked you could literally smash the key and the car would drive and do everything until you turned it off 1 time.
I consider this a non issue. anywhere I would crank my car and get out with it still running, I would just as easily get out with the cranking key still in the ignition. the one thing I do like about my camaro that no other car I've owned will do, is I can crank it, then lock the doors with the key. every other vehicle I have wouldn't even let me lock the doors once it's started, unless I'm in it, with the key. |
#7 |
Drives: 2017 Camaro 2SS 6MT Join Date: Aug 2006
This is one thing I do not like about keyless ignition. I agree, there should be some kind of major warning when you try to drive away without the key inside the car. If anything, it should mute the radio and come up with a big warning on the DIC that the key is not in proximity, vehicle cannot be restarted once shut down, and a fast, loud seatbelt chime should stay on continuously.
Or, the car should simply shut down if you try to drive without the key. |
#8 | |
Someone told me that is their car (non-Camaro), they get a message and a chime that won’t go away, much like you get when driving without a seat belt.
Stirling
#9 |
Who Needs to KNOW?
Sounds like user error.
On previous FORD product, it woudl put warning on DIC that there was no key fob in the car.. and message would not go away. Sounds like something easily fixed with some Dykem ink pens... camaro, red keyfob. There is also those silicon solor keyfob skins.
#10 |
![]() Drives: 2016 Camaro 2SS Join Date: Nov 2016
Every car with keyless start will drive without the key. Although they're supposed to warn you when the key isn't detected, if you get in the habit of keeping it in your pocket this won't happen.
#11 |
#TeamBeckyD
Drives: 2017 HBM 2SS Convertible A8 Join Date: Aug 2008
No issues but I can see how this happens only difference is my key fob shows the convertible top and the others show a lift gate. But in a rush I can see this easily happening.
I do agree the car should not be able to drive away if the keyfob is not w/in say 100-200 ft of the vehicle and this does seem to be a flaw IMHO. Like others have said anyone could hop in your car and drive away.
**FIFTY HBM 2SS VERT** |
#12 |
My Nissan 2012 Maxima would shut off if you went more than 200 feet away from the car with the key FOB in your pocket.
#13 |
![]() Drives: 2017 Camaro SS Join Date: Sep 2017
I did the same exact thing as you and was shocked it drove normal without any warning messages. It is a pointless feature though I can’t stand when I get out of the car after I started to grab something and it starts beeping at me. I struggle to find the benefit over using a traditional key
#14 | |
![]() ![]() Drives: 2016 Camaro 2SS Join Date: Jun 2016
My other cars that have this all warn you (beeps) if your key is outside the car - the Camaro doesn't, which I agree is an oversight. |
