Old 07-25-2018, 09:26 PM   #1
spdfrk81
Drives: 2008 Corvette ZO6, 2018 SS 1LE
AEM Xseries AFR Gauge Power Source
Not sure where this should be posted but i'll start here.
I've got a 18 SS 1LE with a AEM X-Series UEGO with OBDII. I've got the power wire routed thru the firewall to the fuse box under the hood. I'm using a fuse tap adapter to hook it up to the fuse box. I've had it hooked up to 3 different fuses and all 3 power it up just fine however no matter which one it's plugged into the cruise control will not engage. Anyone else come across this issue? Any recommendations on another power source that works with the start button? Thanks
spdfrk81 is offline   Reply With Quote
Old 07-26-2018, 11:10 AM   #2
TJay74
Does it need 12v constant or just switched? I just hooked my AEM Boost gauge up recently.
The part plugged into the OBDII port may be what is hanging you up. Unplug it and try the cruise, if it works then there is your culprit.
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD
Old 07-30-2018, 12:53 PM   #3
hitmix300
2016 loaded 2SS
hitmix300's Avatar
Drives: Maverick X3 Turbo R
I use the ignition coil +12v supply fuse F64 to power to my uego from the same fuse panel with zero issues.
hope this helps
hitmix300 is offline   Reply With Quote
Old 08-04-2018, 06:17 PM   #4
BlueCamaro6
BlueCamaro6's Avatar
Drives: 2018 Camaro 2SS, Hyper Blue
hope this helps
My cruise works with it plugged into the OB2.
2018 2SS, A8, NAV, NPP, MRC, Sunroof, Hyperblue, LT4 S/C, LT4 Fuel System, RotoFab CAI, Headers, HiFlo Cats
2016 2SS, A8, NAV, NPP, MRC, Sunroof, Hyperblue (GM buyback)
1999 Trans Am Firehawk, M6, headers, no-cats, slp exhaust, hot cam, intake, 3:73 gears. Red/Blk
BlueCamaro6 is offline   Reply With Quote
