![]() Drives: None yet Join Date: Jul 2018
Winter tires for 1ss 1LE
Hey there!
I just picked up a 2018 1SS 1LE and I am planning on my winter set up. I saw someone selling a set of stock 2012 Camaro LT 18" wheels with blizzaks locally for a very good price. They are 18x7.5 with ~38mm offset I believe. The tires are 235/60/18. Will these work with the 1LE Brembo's. I know it might be tight, but is it even possible? Thanks! |
![]() Drives: 2016 Camaro 2SS Join Date: Nov 2016
I don't think 18s fit over the 6 piston brakes.
Sent from my iPhone using Tapatalk |
Who Needs to KNOW?
If they are local, test fit before trading cash for tires.
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 2SS Convertible Join Date: May 2012
The 38mm offset may not clear the front suspension, sway bars, and steering.
![]() Drives: 93 RX-7, 17 SS 1LE, 04 RX-8 Join Date: May 2017
![]() Drives: 2000 GMPPSV SS & 2020 2SS Join Date: Jul 2017
#7 |
#8 |
#9 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 2SS Camaro Hot Wheels Edition Join Date: Sep 2015
Zack46
2018 Camaro 2SS Orange Crush Hot Wheels Limited Edition Power Sunroof, 8 Speed Auto/Remote Start, NPP Exhaust Production Sequence Number 98 NEOCC Camaro Club Member Former Ride: 2016 Camaro 2LT RS V6 Hyper Blue Metallic |
#10 |
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Oct 2011
I made spreadsheets to look at tire diameter for various combinations of rims and tires.
Then I made a spreadsheet that calculated the effective width based on offset and everything else. Both of these I was able to compare to stock. I have the radius within 1/4" or so and the width within a few mm, I went with 255 tires for winter. 19" rims. The car is way under-tired with even 255s, I wouldn't go any less. I got my setup so I could drive around in the winter a bit and exercise the fluids, battery, etc.
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
#12 |
![]() Drives: 2019 Satin Steel 1SS 1LE w/ PDR Join Date: Sep 2017
I'm starting to plan ahead for my '19 1LE that I plan to purchase in the winter (to maximize incentives). I remember reading before that 20s were the way to go and to avoid 19s? What's the reasoning behind that? Tire choices? Or maybe I'm confusing that. The more I read about this the more I get confused.
