Old 07-23-2018, 10:36 AM   #1
BDivine76
Drives: 2018 Camaro ZL1
Track Day with the ZL1 - Recommendations Needed
I bought the ZL1 with the intention of doing a couple track days and having fun with the car. It's finally ready with the exception of changing out the brake fluid.
I'm in the So Cal area and looking for some advice on how to get started doing this. I've never done a track day before and I am looking for some good event organizers, clubs, etc. that can help me find some dates at local tracks. Any advice or input is appreciated.
BDivine76 is offline   Reply With Quote
Old 07-23-2018, 11:50 AM   #2
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
speedventures.com is the best guys out there!
Old 07-23-2018, 12:02 PM   #3
MikeEM1
MikeEM1's Avatar
Drives: Tracks: 18' ZL1 1LE
Although it's a must to swap out brake fluid(I like Castrol SRF), I doubt you'll need it for your first time tracking(most likely won't be running the brakes hard enough).
I'm in So Cal, here's some organizers.
Speed Ventures (meh, grid guy is an asshole)
Speed District
LA Track Day
Extreme Speed Track Events
Speed SF
Fast Toys Club
18' ZL1 1LE Red Hot track toy
Endless RF650
Ported TB/Rotofab dry intake
AWE Track w/PLP
APR GTC300 wing / Singular Endplates
ASC Splitter / PA tunnels
MFR Engineering Custom Diffuser
Race Louvers Fender Vents
Trackspec roll bar
Various SPL suspension
Hawk DTC 70/60 pads
APEX SM10 & ARC8
For sale: 2018 OEM ZL1 1LE Wing
12' Nissan GT-R SOLD
MikeEM1 is offline   Reply With Quote
Old 07-23-2018, 12:42 PM   #4
GrabTheWheel
Drives: 18' ZL1 A10
Tip #1 Make sure you get an instructor
Tip #2 I would get an alignment (and swap brake fluid) before your first track day and that's all you need!
Tip #3 Try and familiarize yourself with the track you'll be visiting through videos or however you can
Tip #4 After your first couple days consider swapping brake pads if you drive hard for a whole session and are pushing the brakes the stock pads will be inadequate (Note: you will go through rotors much quicker with track pads)
Tip #5 Motorsportreg.com is your best friend!
GrabTheWheel is offline   Reply With Quote
Old 07-23-2018, 03:23 PM   #5
mr965
mr965's Avatar
Drives: ///M3
^this!
mr965 is offline   Reply With Quote
Old 07-23-2018, 03:35 PM   #6
bwolf11
Drives: 2012 Camaro ZL1/2018 ZL1 1LE
Track Day
For what ever it’s worth, I didn’t do anything other than fill my gas tank up and lowered my tire pressure a bit and then had some fun. Here is a link to some of my laps. The last few laps were the best. Go figure. Chasing the Grey Shelby GT.
https://youtu.be/Pgm-T4DNIrY
bwolf11 is offline   Reply With Quote
Old 07-23-2018, 04:47 PM   #7
BDivine76
Track Day
Thanks everyone for the quick responses! I appreciate any and all feedback.
Best,
Brian
Old 07-23-2018, 06:43 PM   #8
Stealth7
Drives: Gen V Viper GTS
It all depends on how long and how hard you drive. First several times, you are probably good with bwolf11's suggestions. You might add some blue painter's tape to key areas as well, even with PPF (PPF is very expensive).
If you start to drive harder, use Castrol SRF brake fluid and really watch tire pressures. Does anyone here have an idea of the target HOT tire pressures? Once you know this, then you can bleed the tires down to that psi immediately after leaving the track. I would avoid switching brake pads since all changes involve compromises on the street and on your rotors and you are not likely turning pro in this car--everything is for fun.
Finally, BE AWARE OF YOUR SURROUNDINGS ON TRACK AND DO NOT ASSUME THAT THE OTHER DRIVERS WILL FOLLOW ANY RULES OR CONTROL THEIR CARS.
Stealth7 is offline   Reply With Quote
Old 07-23-2018, 11:26 PM   #9
Try2paz
Drives: 1967 Nova
Just finished my first track day.
My prep (just hit 1500 miles)
E diff flush
Three oil changes with last being 15-50
Motul brake fluid
26 psi around ( came up to 32/33/34) off track
Even with stock pads the brakes are amazing
I also did track / track steering and set mode to sport 1
Dry was to intrusive
Try2paz is offline   Reply With Quote
Old 07-24-2018, 09:03 AM   #10
BDivine76
E diff flush
Motul brake fluid
Thanks for the tips! I need to sit down and figure out where/when I'm going to do the first event. I will probably leave the brakes alone, but change the fluid. It's not that big of a deal and I enjoy working on the car.
Old 07-24-2018, 09:08 AM   #11
bwolf11
I think my next track day, I will try Sport 2 or Race pending conditions. If I remember, Race trim is no assistance, your on your own, the good old days.
Old 07-24-2018, 10:00 AM   #12
Try2paz
Drives: 1967 Nova
I forgot to mention I did a 4 wheel alignment to the track settings based on the manual.
I set the rear as described and set the front camber at -2 vs .2.7. I was driving to the track and while Toe typically kills tires I knew my first time out I'm going to be more focused on learning the car vs "kill" mode so I figured id try and save some of my tires as I had a 3 hour drive each way.
