Twin Turbo
Drives: 2016 2SS Join Date: Jul 2016
Pray Performance Stg II Blower Cam **Results Inside**
First off I want to give a Huge shout out to Brett for answering all the messages and annoying little questions I had before ultimately deciding to go with his cam over other popular choices. Never Once did he seem annoyed or bothered by the fact that I asked every question I could think of about installing, what to expect, specs and additional supporting mods. Thanks Brotha!!
With nothing else changed but the cam it picked up 99whp and 29wtq (same dyno before vs after numbers) and most Importantly drives & sounds AMAZING!!! I'm Glad to be a part of the #PrayArmy Mods: Magnuson heatbeat (10 psi) Pray Performance Blower Cam (10% fuel lobe) Kooks 2' LTs (no Cats) LT4 Injectors & Intank Pump LPE Big Bore Pump (Old Version) Roto Fab CAI Stock Npp Stock TB No Meth 93 Octane Pump Gas 718/609 ![]() I Plan to let it eat at the track this fall, then look into a 4xx ci replacement for the SBE. SOUND CLIP CLICK HERE Last edited by SC88; 08-03-2018 at 09:58 PM. Reason: Video Link added |
![]() ![]() ![]() Drives: 2017 Camaro 2SS Nightfall Gray vert Join Date: Jan 2018
Very cool. Congrats!
Magnuson Heartbeat SC - Tuned by JRE Racing 776whp/745wtq (12psi) 2018 Corvette Z06 vert- Black To be tuned by JRE Racing TBD performance |
very impressive and that flat torque "curve"... 7,000 RPM shift point... I'm green with jelly!
![]() Drives: 2017 Camaro 2SS Join Date: Mar 2017
any vid? id like to hear the idle. starting my cam research now but that chop is important! ha
2017 NGM 2SS NPP M6 MRC Vortech SC, 2" TSP LT No Cats, Borla X, Eibach, Hurst shifter 603hp/547tq |
Nice results.
just curious why only 10% on the fuel lobe?
![]() Drives: 2016 CAMARO 2SS Join Date: Apr 2017
VERY NICE!!!
2016 SS A8 STOCK 12.35@113.6 DA 1956
PRAY E85 TUNE,PRAY PORTED IM/TB,ROTOFAB DRY, DRAG PACK 11.33@121.8 DA 1248 PRAY PORTED MSD, 2" TSP LT's 11.38@122.4 DA 3664 GFORCE DRIVESHAFT,LME 174 T-STAT,ATI UDP up next... |
#7 | |
Twin Turbo
https://youtu.be/ZbX2r7QMH5s |
#8 |
Twin Turbo
The LPE Big Bore High Pressure Fuel Pump (Old Version) Will only allow for a Max of 10% fuel lobe increase. Rumor has it the newer design will allow for a larger fuel lobe but I haven't seen anything from LPE that has says that.
#9 |
Drives: 2016 2SS Camaro Join Date: Sep 2016
Healthy!
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 2SS Join Date: Jul 2016
Now get back to even boost from before the cam so we can see what the cam was totally worth. I am glad you are enjoying the cam and the new found power.
#11 | |
Twin Turbo
#12 |
#13 |
I know that has been a few years. I just stumbled on this thread. I was considering something similar. How did it work out over time?
James Montigny
2017 Camaro 2SS A8 - Krypton Green Magnuson 2650 @ 13psi, Forged TSP Rods/Pistons, TSP Ported Heads, BTR PD Cam, Aeromotive Low Side, DSX Flex, LT4 HPFP, 103mm TB, Big Gulp, Meth. Built by Killer Performance, Tuned by Justune. |
#14 |
Twin Turbo
It's still working out. Might be making a switch in the near future due to needing a larger fuel lobe but otherwise solid cam and when matched with a good tuner extremely driveable.
