Old 07-21-2018, 10:09 AM   #1
Itscampos
Drives: 2017 SS Camaro
Unhappy 6gen Wheels and Offset
Hello everyone my name is Jenn. Whats the highest offset we can do on front wheels for a Camaro 2017 SS. I recently purchased ZL1 replicas but I failed to realize that the offset for the front wheels are 35. Do yall think spacers would help out? Any advice would help
Itscampos is offline   Reply With Quote
Old 07-21-2018, 10:24 AM   #2
PNYKLR2
PNYKLR2's Avatar
Drives: 2017 Camaro 1SS Convertible
+ or - 35 offset? What's the factory offset?
If you've already mounted the tires and purchased the wheels see if they will fit without rubbing. If not your good to go! If they stick out past the fenders I would buy some mud guards to reduce damage to your doors and rear quarter panel. Are you still running factory sized tires?
17' Camaro 1SS Vert - Plastidip for 50 Hp gain.
PNYKLR2 is offline   Reply With Quote
Old 07-21-2018, 10:26 AM   #3
PNYKLR2
PNYKLR2's Avatar
If you haven't mounted tires yet just take a wheel off and see if the rim will mount without hitting the brake calipers. Saves you money on mounting and you can try to return your wheels or you could buy spacers. I'm not a fan of spacers but to each their own.
Old 07-21-2018, 10:36 AM   #4
Itscampos
+35, they clear the calipers. The issue is the wheel is to close to the spring. Yes im still using factory tires.
Old 07-21-2018, 11:06 AM   #5
PNYKLR2
PNYKLR2's Avatar
I would see if you can return them. You'll probably eat shipping costs. If you can't return them get the smallest spacer you need to get the clearance you need. Spacers put additional stress on the axle. Think of a lever. The longer the lever the more torque you can apply to something. So, the further out the hub of the wheel the more stress you put on your suspension components.
Old 07-30-2018, 01:33 PM   #6
1018 Video
Drives: 2017 Camaro 2.0T A8
I just put 20x10s on a +23 offset. They are so close to perfect most people wouldnt even notice. Just giving you a point of reference
1018 Video is offline   Reply With Quote
Old 07-30-2018, 04:05 PM   #7
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
The factory wheel specs for both SS 1LE and regular ZL1 are 20x10 +20 front and 20x11 +43 rear. If you have 20x10 +35 wheels then you could install a spacer but it's a bit expensive to buy a quality spacer that thick. You might be better off contacting the wheel company to see what your options are to exchange the wheels if they have a different size.
Mark114 is online now   Reply With Quote
Old 07-31-2018, 12:07 AM   #8
JeromeS13
Drives: 2017 1SS/1LE
Who makes ZL1 replicas in a 20x10 +35??? The MRR replicas are OEM sizes 20x10 +23 and 20x11 +43...
