Old 07-18-2018, 02:00 AM   #1
1981DFA
1981DFA's Avatar
Drives: 2017 Camaro ZL1
A penny for your thoughts
So I added a the Roto fab cai and had the car dyno’d today and she made 594 rwhp. I’m thinking this is pretty high for just a cai. I bought the car slightly use and know that the pervious ower had the same cai on it at some point. Just wondering if anyone thinks it was tuned or is this normal for the ZL1 to pick up that much power with just a cai?
2017 Hyper Blue Metallic Camaro ZL1 Stock. For now.
1981DFA is offline   Reply With Quote
Old 07-18-2018, 04:29 AM   #2
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
70% chance it's the dyno, not the car. CF# not shown.
20% chance the car was tuned (but torque is still relatively normal). Lambda not shown.
10% chance you got a lottery winner of a car.
Old 07-18-2018, 10:28 AM   #3
SJFGTO
Oh Oh it's Friday Night!
SJFGTO's Avatar
Drives: 2018 ZL1 1LE Nightfall Gray
Allot of variables on any dyno run. The HP numbers are a bit high for a CAI alone, but you could go tomorrow to a dyno jet down the road and get numbers that are a bit low. Enjoy the bragging rights!!!
Four that wanna own me
Two that wanna stone me
One says she's a friend of mine...
SJFGTO is offline   Reply With Quote
Old 07-18-2018, 10:45 AM   #4
1LE Red Dragon
Train Driver
Drives: 2018 Summit White ZL1 1LE
You have 578, 582, and 594 whp numbers. Is one or two of them before the intake? Or if they all have the intake, what was the cause of the difference in the numbers? Was it heat? What got it up 16 whp from teh 578 pull?
2018 Camaro ZL1LE
/ / Katech TB // RotoFab Dry // Borla 60606 // ATI Super Damper / /
1LE Red Dragon is offline   Reply With Quote
Old 07-18-2018, 01:02 PM   #5
1981DFA
1981DFA's Avatar
All pulls were done after the cai install. The 594 pull was done after a 45 min cool down. The other two were done back to back right after I got to the shop. I know each Dyno is different and there are a lot of factors involved. That being said the tq number look normalish it was about 90 degrees outside with about 50% humidity.
Old 07-18-2018, 01:16 PM   #6
Stealth7
Drives: Gen V Viper GTS
Why was torque so much less than HP on a 650/650 motor?
Stealth7 is offline   Reply With Quote
Old 07-18-2018, 03:10 PM   #7
kttxz06
kttxz06's Avatar
Drives: '18 Zl1. '18 GT350.
What are air temps? Bring that down here to Houston and watch those #'s tank. haha.
There's only 2 people I trust. 1 of them is me, the other's not you. 2018 Zl1. 1199 RWHP/931 TQ.
kttxz06 is offline   Reply With Quote
Old 07-18-2018, 03:20 PM   #8
Larrio Andretti
Drives: Really Fast
Horsepower numbers should be corrected for non standard temperature and pressure. The numbers in Texas should be no different than the numbers for the same car in Denver with the correction applied.
Dynojets read high since there’s no load applied. Unless It’s an eddie current hybrid Dynojet.
THIS SPACE FOR RENT
Larrio Andretti is offline   Reply With Quote
Old 07-18-2018, 03:55 PM   #9
hawk02
Coupe Newbie
hawk02's Avatar
My guess it's the Roto-Fab intake.
If you look at the dyno sheet from the Roto-Fab product announcement, you'll see that it actually lost peak torque versus the stock intake.
Old 07-18-2018, 04:58 PM   #10
TLSTWIN
Romans10:9-13
TLSTWIN's Avatar
Drives: /\yes, this is me/\
What I did with my vararam on my 5th gen Was do a dyno baseline stock, then while on the dyno, shut it off, swap out the intake and do it again.
do the actual swap a few times before going down to the dyno so you know exactly how to do it, what tools you need, etc. Stream line the process to eliminate time between runs
TLSTWIN is offline   Reply With Quote
Old 07-18-2018, 05:25 PM   #11
hashtag
hashtag's Avatar
Drives: 2018 ZL1 A10/2018 GT350R #JR603
High heat “90 Deg” w/ 50% humidity = retarded timing especially on forced induction.
Imagine how high those numbers would be on a 60 degree day w/ 25% humidity.
2018GT350R+2018 ZL1 "Red Hot" A10 w/ PDR, Nav, Carbon Fiber Hood insert, Carbon Fiber Dash Insert, Carbon Fiber Fuel Dior & Sun Roof. T/M T-Body, Roto Fab & Borla S Type.
hashtag is offline   Reply With Quote
Old 07-18-2018, 05:55 PM   #12
Larrio Andretti
Drives: Really Fast
Those numbers are SAE corrected. They would be exactly the same. Humidity is a negligeable factor when it comes to performance.
THIS SPACE FOR RENT
Old 07-18-2018, 07:55 PM   #13
lt4camaro
lt4camaro's Avatar
Drives: 2021 LT1 10 speed auto
So go by the 578 and the 582, not the cooled down run. A cool dyno pull is for bragging rights or a hero run, the other two are real world repeatable numbers because you will always be heat soaked before a race.
lt4camaro is offline   Reply With Quote
Old 07-19-2018, 09:49 AM   #14
1981DFA
1981DFA's Avatar
Well I think I’m going to have it looked at just to see if it has been tuned. Just out of curiosity.
