Old 07-17-2018, 08:45 AM   #1
TheSoundOfFreedom
TheSoundOfFreedom's Avatar
Drives: 2018 ZL1, Garnet Red Tintoat, 6spd
Manual 1-4 shifting
Anybody else with the manual trans as sick and tired of the second gear lock out when it tries prompting a 1-4 shift as I am? Other than the thigh bolsters on the seats being really tight which isn’t horrible, just could be a tad wider but the second gear lock out is actually irritating to me. Is there any simple solution to disabling it?
Fuel economy isn’t anywhere near, let alone on my list of priorities.
TheSoundOfFreedom is offline   Reply With Quote
Old 07-17-2018, 08:51 AM   #2
Michael52
Michael52's Avatar
Drives: 2018 Black ZL1, 1977 Yellow 308GTB
Just take your revs a little higher in first and it will not happen. I have only seen it pop up 2 maybe 3 times and only when I have been coasting very slowly in first.
Michael52 is offline   Reply With Quote
Old 07-17-2018, 09:01 AM   #3
Lethal Z
American Gearhead!!
Lethal Z's Avatar
Drives: ZL1 1LE/GT350/Ford RS/Gen 2 Raptor
You can buy a plug in module that disables it, but the easiest solution is just to step on the gas pedal.
https://www.phastekperformance.com/2...SAAEgJmwfD_BwE
Lethal Z is offline   Reply With Quote
Old 07-17-2018, 09:01 AM   #4
hawk02
Coupe Newbie
hawk02's Avatar
Shift from first to second above 19 mph and you'll never experience the second gear lock out.
Old 08-31-2018, 10:36 AM   #5
TheSoundOfFreedom
Thanks for the replies fellas. Throttle input is of course the simplest solution not always possible depending on traffic conditions. I did see recently a few tuners that can disable it as stated above. Will definitely be doing that, the permanent solution.
Old 08-31-2018, 10:54 AM   #6
Frisbey
Drives: 2018 Camaro ZL1 Nightfall Grey
Just shift at a slightly higher rpm, or
Double clutch, defeats it, or
Buy the skip,shift eliminator
It’s a ridiculous feature btw
Frisbey is offline   Reply With Quote
Old 08-31-2018, 11:25 AM   #7
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
As you mentioned - it can be turned off permanently in the tune or you can install the eliminator cable. I did the tune out on my fifth gen and that was great. For my sixth gen I just shift above 19 mph or if I forget and hit the lockout i just shift to third. It will let you do that and third doesn't lug the engine like fourth.
476 rwhp/440 rwtq (sold)
Old 08-31-2018, 12:12 PM   #8
nancygrl
雪の玉
nancygrl's Avatar
Drives: '22 Z71 RST Silverado
When GM started the 1 to 4 shift on 6spds way back when.......Something I tried and worked back in 1996 with my 6spd Trans-Am was when I wasn't paying attention driving around town so when I felt a 2nd gear lock out, instead of going to 4th I tried going straight to 3rd instead, it let me do it and it didn't bog the car down as bad as going into 4th. It's something I've been doing ever since.
nancygrl is offline   Reply With Quote
Old 08-31-2018, 12:21 PM   #9
Raven87
C'mon- really?
Raven87's Avatar
Drives: Looking for a ZL1
I was not aware of this! I will be trying it this evening and hope it works. I've always just shifted above 19 mph to avoid the aggravation.
Steve
2018 Camaro 2SS 1LE Black #3805 - SOLD
Raven87 is offline   Reply With Quote
Old 08-31-2018, 12:27 PM   #10
nancygrl
雪の玉
nancygrl's Avatar
It worked on both of my 5th gen M6's...Not sure about 6th gen, I suppose it should..........For the short time I had the '17ZL1 it was never an issue
Old 08-31-2018, 12:51 PM   #11
Raven87
C'mon- really?
Raven87's Avatar
You had a ZL1 and went to the SS? Just curious as to why? Was there something about the ZL1 you did not like? I trade a lot/often too so I can understand!
Steve
Old 08-31-2018, 02:15 PM   #12
nancygrl
雪の玉
nancygrl's Avatar
I went back after being without a Camaro for 7 months, it happed to be a SS; a v6 RS would've been fine too....ZL1 was awesome, but I can have my Silverado 4x4 and Camaro for what the ZL1 cost.
Old 08-31-2018, 02:19 PM   #13
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
First to third... works well!!!!
Old 08-31-2018, 03:45 PM   #14
HDRDTD
FWIW, using a tune to disable it will void your warranty.
Installing the Skip Shift adapter cable is easy, quick, and only costs around $15-20 or so.
Skip Shift is designed to only engage under certain conditions, a combination of speed and throttle position. Shifting at a higher rpm will prevent it from engaging.
Even if on rare occasions it kicks in on my ZL1, I discovered that all you have to do is shift to neutral for a second, pause, then slip it into second. Piece of cake.
Pick a solution for you.
