Old 07-16-2018, 09:35 AM   #1
apexit53
apexit53's Avatar
Drives: 22 1SS 1LE Summit White
Track day brake fluid!
Hey everyone!
Just wanted to ask for those that track their cars what brake fluid you are using?
Just not sure if the OE stuff can handle a track day or not.
#53 F Street
2025 FS National Champion
2025 Sponsor autocrossdigits.com
Autocrossing Videos
https://www.youtube.com/channel/UCm-...3tiMt0KOg_2Aag
Instagram: apexit_53
apexit53 is offline   Reply With Quote
Old 07-16-2018, 09:39 AM   #2
RXtacy
RXtacy's Avatar
Drives: 93 RX-7, 17 SS 1LE, 04 RX-8
Originally Posted by apexit53 View Post
Hey everyone!
OE fluid will not handle track abuse.
Motul RBF 600 or 660, or Castrol SRF are the go to fluids IMHO.
RXtacy is offline   Reply With Quote
Old 07-16-2018, 09:42 AM   #3
Sp00ner
Sp00ner's Avatar
I went with Motul last year, SRF this year. Both of them worked just fine, though I did bleed a bit of the Motul every other event. The SRF I've just let ride for 3 so far. No boiling, no soft pedals with either, even on 90+ degree days.
Track ducting in place for all events.
Sp00ner is offline   Reply With Quote
Old 07-16-2018, 09:47 AM   #4
apexit53
apexit53's Avatar
cool i didn't think so especially road america.
I drive my car year round, do you think these would handle the winter or should I remove it before it gets too cold out.
#53 F Street
Autocrossing Videos
Old 07-16-2018, 10:44 AM   #5
apexit53
apexit53's Avatar
Also I know why i had some other cars when doing brake fluid there was a special order you had to bleed the calipers in. Anyone know that order of maybe have a link to it?
Thanks
#53 F Street
Autocrossing Videos
Old 07-16-2018, 10:47 AM   #6
trohde78
trohde78's Avatar
Drives: '17 Red Hot 2SS 6MT
Thanks
You bleed the furthest wheel from the master cylinder to the closest. RR, LR, RF, LF
I run Motul DOT 5.1, and also used it in my BMW's. It's not quite as extreme as the racing fluids mentioned above, but it's a very nice upgrade from stock, and will work year-round without issue.
trohde78 is offline   Reply With Quote
Old 07-16-2018, 11:14 AM   #7
apexit53
apexit53's Avatar
awesome thank you sir!!
#53 F Street
Autocrossing Videos
Old 07-16-2018, 11:33 AM   #8
Sp00ner
Sp00ner's Avatar
No issues leaving it in year round. Mine is my winter car, summer car, kid hauler, etc. I just swap out the brake ducting and splash shields for the start of Summer/Winter respectively.
...and snow tires...
Old 07-16-2018, 11:40 AM   #9
apexit53
apexit53's Avatar
Yeah I have to swap the brake duct stuff on and off right away because its not legal to run for Ftreet autocross class. its not to hard to do though.
#53 F Street
Autocrossing Videos
Old 07-16-2018, 11:47 AM   #10
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
i use motul 600 but anything is better than stock lol
Old 07-16-2018, 02:14 PM   #11
Nick S
Nick S's Avatar
Drives: 2013 Camaro 1LE
Hey everyone!
What track day are you going to be running Mike?
I have been running Motul 600RBF in my car and I have not had any issues. I do try to make sure I bleed 2 or 3 pedal pumps from each bleeder screw before a track day/weekend though just to get some fresh fluid into the caliper.
Nick S is offline   Reply With Quote
Old 07-16-2018, 02:44 PM   #12
apexit53
apexit53's Avatar
Milwaukee scca is hosting a track day at road america august 7th.
Thats good to know, just gota find someone to swap my fluid out now!
#53 F Street
Autocrossing Videos
Old 07-16-2018, 06:24 PM   #13
Nick S
Nick S's Avatar
Make sure you check your brake pad thickness that you have left. You don’t want to plan on running a full day at RA with less than half pad thickness to start with. Also what brake pads are you planning to run at RA?
Old 07-17-2018, 08:17 AM   #14
apexit53
apexit53's Avatar
I have some rotors and pads on order just to use for that track days specifically. autoX wise the car is perfect and dont want to change anything i cant revert back! hah
#53 F Street
Autocrossing Videos
