Old 07-16-2018, 01:14 AM   #1
meSSohappy
meSSohappy's Avatar
Drives: 2018 ZL1 A10
eLSD slippage when entering steep approaches
I’ve noticed on 2 separate occasions now when exiting a flat street into a steep driveway or exit that my rear diff will slip or my wheels aren’t turning at all. I always approach on an angle so not to rub splitter but weird things happening in the back. Is this normal?
DAVENPORT STAGE 2 PLUS - 2" ARH ceramic coated headers - 3" ARH catless exhaust - Stock NPP mufflers - Kong ported SC - Katech 103 ported TB - Rotofab 5" Big gulp CAI - 22.5% lower pulley - ATI Harmonic balancer - Cordes SC expansion tank - MSD hi temp ignition wires - Koolsox spark plug insulators - custom tunes - 660hp/725tq pump - 713hp/763tq race
meSSohappy is offline   Reply With Quote
Old 07-16-2018, 01:21 AM   #2
Larrio Andretti
Drives: Really Fast
With a stiff chassis like the Camaro yes. The inside rear wheel becomes unweighted and the eLSD compensates for that wheel slipping.
THIS SPACE FOR RENT
Larrio Andretti is offline   Reply With Quote
Old 07-16-2018, 02:23 AM   #3
nicktechla
nicktechla's Avatar
Drives: 2012 Porsche 911 Turbo S
Sometimes mine 3 wheels into parking lots
IG: 2fast2nick
-- Current --
2012 Porsche Turbo S - PDK - Basalt Black Metallic
-- Past --
2017 Camaro ZL1 Coupe - Red Hot - A10, PDR - HRE P101
2015 Mustang GT PP - Whipple Supercharger
nicktechla is offline   Reply With Quote
Old 07-16-2018, 04:38 AM   #4
hashtag
hashtag's Avatar
Drives: 2018 ZL1 A10/2018 GT350R #JR603
Yes that tends to happen. Like when I complain to the technicians at work and they respond back to me, it is a race car.
2018GT350R+2018 ZL1 "Red Hot" A10 w/ PDR, Nav, Carbon Fiber Hood insert, Carbon Fiber Dash Insert, Carbon Fiber Fuel Dior & Sun Roof. T/M T-Body, Roto Fab & Borla S Type.
hashtag is offline   Reply With Quote
Old 07-16-2018, 10:35 AM   #5
17CamaroZL1
Life's Short, Live Fast!
17CamaroZL1's Avatar
Perfectly normal. I've had that happen 3 or 4 times now. I've always backed up a bit and then pull up at a little faster speed so the tire that's off the ground can carry across until it touches again. This last time though, I wanted to see if the diff would eventually start locking, so I kept a very slight steady throttle applied, and the car stopped for a second with one tire slightly spinning and then it started going on up. So either a rock or something got pulled under the tire or the diff locked up.
12/26/2016 Ordered!
2/8/2017 Built!!
3/2/2017 Brought Home!!!
Old 07-16-2018, 11:10 AM   #6
meSSohappy
meSSohappy's Avatar
Thanks all....figured it was normal but needed to ask !!
Old 07-16-2018, 02:18 PM   #7
big dave
Drives: 2017 ZL1
I'm so glad you posted this. This happened to me last summer and I had no idea how the replicate the problem when taking it to the dealership. The car absolutely would not move forward. I tried going up the same steep grade from both directions and it just would not go. Eventually i was able to go straight up the incline but backing my car up to where it was pointing straight ahead towards the incline.
'17 ZL1 10.99@129 stock. 4225# raceweight. Best 60'- 1.66 on factory tires. 10.48@132 E50, intake and tune. 4270 lbs
https://youtu.be/EyHtdH9XOkY
https://youtu.be/Lcu41obbTf8
'13 ZL1 BRM A6. 11.591 @ 119.2 factory stock with a 1.68 60'! Best stock mph 121.8. 11.29 @ 123 RotoFab, drag radials and skinnies. 4360# raceweight.
http://youtu.be/yggIA3C_kkA 2014... back to stock
http://youtu.be/spQLaTWbThs 2013... stock & RotoFab
big dave is offline   Reply With Quote
