Old 07-15-2018, 09:19 PM   #1
Desenski
Desenski's Avatar
Drives: 2018 2SS 1LE
1LE Transmission Fluid Capacity
So I know the standard SS M6 takes 4 quarts for a transmission fluid change. But the 1LE has a transmission cooler, so doesn't our take more fluid?
Desenski is offline   Reply With Quote
Old 07-16-2018, 01:59 AM   #2
JeromeS13
Drives: 2017 1SS/1LE
The SS has the same cooler.
Old 07-16-2018, 10:16 AM   #3
TJay74
No, uses the same 4qts of fluid.
Old 07-16-2018, 01:09 PM   #4
Desenski
Desenski's Avatar
Hmm. I was under the impression that the transmission cooler was part of the 1LE package.
Old 07-16-2018, 01:25 PM   #5
JeromeS13
No. It was just mentioned as a marketing tidbit. The regular SS has the same setup.
Old 07-16-2018, 01:26 PM   #6
Desenski
Desenski's Avatar
Slightly disappointing, but alright. Thanks for the information.
Old 07-18-2018, 11:48 AM   #7
SaphfireSS
Drives: 2017 Camaro 1LE SS
From what I've read the 1LE has a slightly larger cooler. Just sayin.
SaphfireSS is offline   Reply With Quote
Old 07-18-2018, 12:00 PM   #8
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
Where did you read this?
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph
Old 07-19-2018, 11:28 PM   #9
thescreensavers
thescreensavers's Avatar
Drives: SW 1SS 1LE / Jeep XJ
SS is also a track model, the 1LE just adds to it.
thescreensavers is offline   Reply With Quote
Old 07-22-2018, 10:57 AM   #10
SaphfireSS
Don't remember. But it also sends trans fluid back to rear diff to cool that heat exchanger as well. I'm pretty sure the SS doesn't have that feature but none the less it still only takes 3.6? Qts for a fluid change.
1le, ss 1le, transmision, transmission fluid
