Old 07-15-2018, 02:40 PM   #1
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
Blown (?) DSSV on ZL1 1LE
Was driving the car around after a wash and noticed the RF was making a new rattle/clunk everytime the car went over a bump in the road. Figured it may be related to the sway bar end links so I put the car in the air and started checking for bolts. I didn't find any loose bolts, but what I did find was a bunch of grease on the bottom of the RF damper. All other corners are clean with no leaks. Car has 3k miles on it, about 10 track days.
I know there was a recall on the DSSV's on the Colorado ZR2, "...may have a leaking front shock absorber. noise as a result of contact between the upper control arm and service stop, as well as a potential fractured shock absorber piston rod." Could be the source of my sound...
I suppose I will be contacting a local dealer tomorrow.
Just to add to this, what I'm referring to is grease coming out of the "breather" valve on the bottom side of the shocks. As I understand it, this grease is for internal lubrication and is not actually part of the "damper" and leaks can occur here. However, there was A LOT of grease on the bottom of the strut and knuckle of the car.
seanblurr is offline   Reply With Quote
Old 07-15-2018, 02:47 PM   #2
camareoZ
camareoZ's Avatar
Drives: 2018 Camaro ZL1 1LE (Black)
bump
camareoZ is offline   Reply With Quote
Old 07-15-2018, 02:53 PM   #3
waterman
waterman's Avatar
Drives: Grandad's C2 L89
Just to add to this, what I'm referring to is grease coming out of the "breather" valve on the bottom side of the shocks. As I understand it, this grease is for internal lubrication and is not actually part of the "damper" and leaks can occur here. However, there was A LOT of grease on the bottom of the strut and knuckle of the car and the breather appears to be gone.
Subscribed. Please keep us posted.
2018 ZL1 1LE sw/PDR
Old 07-15-2018, 06:32 PM   #4
bensf
bensf's Avatar
Drives: ZL1 1LE
I have the same issue on the same (RF) damper but without the clunking noise
2018 Camaro ZL1 1LE
2015 GT3 (gone)
2011 Boxster Spyder
bensf is offline   Reply With Quote
Old 07-15-2018, 06:34 PM   #5
FNxR3DNECK
FNxR3DNECK's Avatar
Drives: 2017 SS 1LE
I just had my ZR2 checked for that when I took it in for the free oil change last week, it was good thankfully. It definitely sounds like the same thing that was happening to the ZR2s...
IG: @NC_M1SS1LE
Old 07-15-2018, 07:44 PM   #6
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
The clunk does sound very similar as if it had loose end links, though they are definitely tight.
Old 07-15-2018, 09:19 PM   #7
WhiteBoy18
WhiteBoy18's Avatar
Drives: 2018 ZL1 Summit White M6
https://www.camaro6.com/forums/showthread.php?t=506938
Same issue and it was the end links...above is the tsb for it. Hope this helps!
WhiteBoy18 is offline   Reply With Quote
Old 07-15-2018, 10:05 PM   #8
devnull
Scientific negotiator
devnull's Avatar
Drives: 2019 Grand Sport
I would loosen and retorque the end links. At least it’s easily repeatable. Very odd
2019 Grand Sport M7
2018 ZL1 1LE 6MT
2017 SS 1LE 6MT
Matthew 25:40
ΜΟΛΩΝ ΛΑβΕ
devnull is offline   Reply With Quote
Old 07-15-2018, 10:29 PM   #9
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
I will loosen and retorque just for peace of mind, however, that doesn't change the absurd amount of grease on the bottom of the strut, knuckle, and brake caliper which is the main concern that I initially posted about.
Old 07-15-2018, 10:32 PM   #10
devnull
devnull's Avatar
I will loosen and retorque just for peace of mind, however, that doesn't change the absurd amount of grease on the bottom of the strut, knuckle, and brake caliper is still quite a concern though.
Yeah I agree, I’d just want to me 100% on those links. The grease may be a different issue. Certainly possible, but my head just doesn’t wrap around that sound being the damper.
2019 Grand Sport M7
2018 ZL1 1LE 6MT
2017 SS 1LE 6MT
Matthew 25:40
ΜΟΛΩΝ ΛΑβΕ
Old 07-15-2018, 10:33 PM   #11
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
That was my exactly thinking, I've never seen a damper make a sound like that.
Old 07-18-2018, 09:49 PM   #12
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Drives: 2018 ZL1 1LE
Did you hear anything from the dealer about the grease blown out of the bottom of the shock?
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is offline   Reply With Quote
Old 07-19-2018, 11:11 AM   #13
wlsmoku
Drives: 2018 ZL1 A10
my Zl1 is making a very similar noise on the LF. I need to inspect it asap!
wlsmoku is offline   Reply With Quote
Old 07-19-2018, 09:18 PM   #14
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
Guys just to update, I've had this car up to check and recheck. It is definitely not the end links. Dealer appointment on Monday. I'm still hard-pressed to believe it's the damper making this sound.
