Old 07-15-2018, 02:21 PM   #1
jdoll
jdoll's Avatar
Drives: 2016 white 1SS
Procharger belt ?
Need some help figuring out which belt I'll need for the new pulley. D1X has a 4.25 pulley on it at the moment, going to a 3.85. Any idea how much shorter it needs to be?
Thanks for any input.
jdoll is offline   Reply With Quote
Old 07-15-2018, 03:43 PM   #2
oldman
Drives: SS 6 speed of course
was going to ask the opposite question, what belt are you using now... Just got my d1x with 4.50 pulley
Old 07-15-2018, 03:51 PM   #3
jdoll
jdoll's Avatar
These are the number I could find on it. Hope they help!
Old 07-15-2018, 09:01 PM   #4
oldman
HP Addicts says I need a gates Gates 465-K080653 for a 4.5 pulley and that specs out to 65.922 inches OD. My 4.0 pulley came with a Napa 25-080645 which has a pitch length of 64.5. Don't ask me what pitch length is, I thought the Napa belt was a little loose and was near the max adjust of the tensioner...
Old 07-15-2018, 09:28 PM   #5
TJay74
The 08-645 is the stock belt size on the 4.25" pulley, if you look for a Gates belt as the parts store to put a "HD" at the end of the part # for the heavy duty belt that doesn't stretch as much.
You will need a smaller belt for sure. The formula for circumference is 2*Pi*R^2
If the stock pulley is 4.25" (This is the diameter) then the radius is 2.125". The circumference of that pulley is 13.35" which is 339.04mm.
The 3.85" pulley has a circumference of 12.1" which is 307.34mm. That is around 32mm smaller in circumference.
I would say start with a 25mm smaller belt and go from there.
Old 07-15-2018, 09:29 PM   #6
TJay74
Oldman you needed a smaller belt as well for that 4.0" belt.
