Old 07-15-2018, 11:45 AM   #1
UberDragon
UberDragon's Avatar
Drives: 2018 Camaro RS Metallic Black-Out
Camaro Defrost Covers with OEM Appearance
Has anyone come across a defrost vent cover with an OEM look yet to solve the leaking AC issue? I'm in the market Please link me!
Having a 2018 here in New Orleans, while it's not at the level of being dangerous for me, it happens every day and is annoying! (And yes I know how to deal with it with wipers, and blasting the heat etc.. I'm just tired of having to do those things)
I've got some great ideas for it, such as rubberized piping so when it slips in place it actually seals. Whoever makes this product with a true OEM appearance/feel is going to be rich if they aren't already lol.
If this product still doesn't exist as we go into the 6th gens 4th production year, anyone know where I could find a template of that vent space so I could try to make my own?
_________________________________________________
2018 Camaro RS - Metallic Black-Out -- (Black Betty)
2011 Harley Davidson Softail Cross Bones FLSTSB -- (LowBo)
UberDragon is offline   Reply With Quote
Old 07-15-2018, 12:43 PM   #2
craigss50
craigss50's Avatar
Drives: 2017 Camaro SS Fifty
I had the same problem down here in South Florida. I made one out of 1/8" thick black rubber and only covered the top 1 1/2" of the defrost grill (part closest to windshield) so that air still comes out but is not directed at the windshield. I traced the outline of the vent on a piece of paper, cut and taped it to the rubber and trimmed with scissors. Fastened it with 3m double sided trim tape. Outcome is ok but I would also like something more OEM looking. I no longer have the fogging issue so I am happy with it.
craigss50 is offline   Reply With Quote
Old 08-21-2018, 06:29 PM   #3
Blackboy1577
Blackboy1577's Avatar
Drives: 2018 Camaro SS convertible
Do you have a pic? And where did you buy the rubber? Im in south florida also and this aggravates the living shit out of me. Lol!
Blackboy1577 is offline   Reply With Quote
Old 08-21-2018, 07:32 PM   #4
zr1chris
zr1chris's Avatar
Drives: 2018 Camaro 1SS/1LE
I'd also like to know a solution for this.
How hard is it to do what you guys did with the rubber piece?
zr1chris is offline   Reply With Quote
Old 08-21-2018, 07:46 PM   #5
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
An oversize mouse pad or just a big piece of neoprene does the trick.
https://www.amazon.com/Extra-large-G.../dp/B0713N6CFC
Old 08-21-2018, 08:40 PM   #6
craigss50
craigss50's Avatar
The rubber is cut from a piece of stair step mat. I traced the outline on a piece of heavy paper cut and sized to fit. Use 3m trim tape to tack it down to the defrost grill. I only taped the edge close to the windshied so the rear of the rubber can blow up a little so some air would come out but not aimed close to the windshield. Works great. Looks ok. BTW the oversized mouse pad looks like it would also work.
Old 08-22-2018, 12:36 PM   #7
SSJ455
SSJ455's Avatar
Drives: "Kara Zor-El" 2017 2SS HBM
I have done something like this, the only issues I have now are the cold air coming from the side defroster vents and the rubber also out gasses onto the windshield. When I park, I take the cover off and then put it back on when I use the car.
Has anyone made any covers for the small vent for the side windows?
Lead me not into temptation. I already know the way.
Lana? Lana? LANA! LAAANAAAA!!!!
What?
Dangerzoooooone.
SSJ455 is offline   Reply With Quote
Old 08-22-2018, 01:06 PM   #8
00 Trans Ram
00 Trans Ram's Avatar
Drives: 2017 2SS
Well, I had a thread with pics in it, but it looks like the pics have gone bye-bye. https://www.camaro6.com/forums/showt...hlight=defrost
Basically, made a template out of paper, then transferred the template to 3M Di-Noc. I originally used carbon fiber (because that’s what I had laying around).
A bit of an update to that thread. The tape I used eventually became less sticky. And, the paper warped a little. I remade it using the same 3M Di-Noc stuff, but this time in flat black. And, I just stuck it directly to the vent.
It’s been over a year now, and it’s held up perfectly in 100* heat and 20* cold.
I’m here in New Orleans (work downtown and live in Harahan). If you want to meet up somewhere so you can see it, let me know.
00 Trans Ram is offline   Reply With Quote
Old 08-22-2018, 03:05 PM   #9
KirkH
The problem is the difference in temperature, not really the fact that air is blowing on it. As long as the area is colder than the outside temperature and it is humid outside, its going to fog.
A guy commented on my YouTube video of this problem that he got the fix done at the dealership, and it still fogs up.
Old 08-22-2018, 04:18 PM   #10
SSJ455
SSJ455's Avatar
With the cover over the air vents near for the windshield I get no fogging up regardless of how cold I have it in the car and how warm and humid it is outside. I put the AC to 67-68 and the temp outside is 85-95 with 70+% humidity.
What?
Dangerzoooooone.
Old 08-22-2018, 09:14 PM   #11
DavidinGA
Tread Marks
Drives: 2016 Hyper Blue Camaro 2SS
I'm in GA, so we're super humid down here. What I do is running the ac at a higher temp; easy solution. I generally run the ac at 74f or so and have no issues.
Sent from my Pixel 2 XL using Tapatalk
DavidinGA is offline   Reply With Quote
Old 08-22-2018, 09:22 PM   #12
Gunkk
Gunkk's Avatar
+1
Old 08-23-2018, 09:28 AM   #13
majik755
majik755's Avatar
Drives: 2017 Camaro RS Fiftieth Anniversary
I found this frustrating, but in another post on here, another member mentioned switching the vent function from Auto to the floor and dash vents. Since I did that, i have not had the problem. Makes sense, no cold air on windshield, no condensation from outside humidity.
majik755 is offline   Reply With Quote
Old 08-23-2018, 11:32 AM   #14
HighIron
Drives: 2024 2SS Summit White
Along those lines: Find out what the dewpoint is ( which is an infinitely more reliable/accurate way of determining the actual level of humidity than relative humidity ) and run the A/C at a value just a tad higher.
HighIron is offline   Reply With Quote
camaro, cover, defrost, vent
