![]() Drives: Gen V Viper GTS Join Date: Jan 2018
Locations for Placing Jack Stands when Jacking the Car
Does anyone have any photos or descriptions they could share on the use and placement of Jack stands when jacking up the car with a low-profile jack? I like to see this:
A. By Wheel. B. By Front End. C. By Rear End. That is, the jack, puck and ZL1-Addons device will go on the jack at the jacking point for a given wheel or end of the car (TBD). Once the car is jacked up I want to place the jack stand somewhere for safety. Obviously, this cannot be the same jacking point as the jack is using. I have ESCO low profile Padded Jackstands and Wheel Chocks. Thanks very much! T |
![]() ![]() ![]() ![]() ![]() Drives: Grandad's C2 L89 Join Date: May 2017
If you look closely you will see two pinch welds near every jack point. It’s in the owners manual. Up front, use the back weld to lift and the forward weld for your jack stand. Opposite in the rear. Chassis is super rigid so the entire side will raise when lifting. Same with front and rear. Love me some Alpha platform.
It’s easy to locate with ZL1 rockers as there are cutouts. Diagrams in the manual.
2018 ZL1 1LE sw/PDR
Never thought of lifting the entire side of the car to work on one wheel!
Thanks! |
Thank you Al Oppenheiser!
https://www.camaro6.com/forums/showp...7&postcount=12
For more, head over to the maintenance section and search for "jack" or "jacking." Tons of good info over there. |
Scientific negotiator
Drives: 2019 Grand Sport Join Date: Mar 2017
We have no choice, both wheels come up anyway haha
2019 Grand Sport M7
2018 ZL1 1LE 6MT 2017 SS 1LE 6MT . Matthew 25:40 ΜΟΛΩΝ ΛΑβΕ |
Thanks very much!
#7 |
Drives: camaro Join Date: Jul 2018
is it safe to lift car like that without bending frame and doors
#8 | |
That rigidity is what makes your Camaros handling light years above the competition. As long as you are lifting on the recommended points (pinch welds) as recommended by the manual, you are golden.
2018 ZL1 1LE sw/PDR
#9 |
i was thinking about doing oil change by lifting one side does that work?
#10 |
![]() Drives: 2018 A10 ZL1 Join Date: Jul 2012
You could, but you would likely leave some oil in the pan that way. The drain is located off the rear central area of the pan. I lifted the front (when you lift the second side the rear will come back down to the ground). Used a jack stand on one side and one ZL1 addon jack safety stop for the other. Worked great.
#11 |
![]() Drives: 2018 Red Hot ZL1 1LE Join Date: May 2017
Super happy to see your jack cleared! That's good news for me!
2018 RED HOT ZL1-1LE: Nav,PDR,Floor Mats
Built! |
#12 |
雪の玉
Drives: '22 Z71 RST Silverado Join Date: Feb 2011
I get how and where to jack the car up....what is not clear in photos and videos I've seen is how the jack stand cradle sits/rests on the pinch weld. The pinch welds are thin and straight and jack stands are sort of flattened out U shape. I have one set that has a notch in the bottom of the U that looks like it might be for using with pinch welds. This will be 1st time I have to lift and support the car.....Gonna be doing the Sema grille so I'll need to jack up the front and take the wheels off to get at all the bolts behind the bumper......... Nervous as hell
#13 | |
https://youtu.be/azDER9QSKE8
2019 Grand Sport M7
#14 |
Yeah use the ZL1addon jack points. It gave me more clearance than just pucks did!
2019 Grand Sport M7
