Old 07-13-2018, 03:37 PM   #1
ZL14ME
Drives: 2018 ZL1 M6
Rough idle question
I know there has been rough idle discussion here in the past and I’ve gone back and read some of them. I haven’t seen a solution or follow up type response from the Op in those threads so I need a ask...
I went out to drive my ZL1 this morning. It’s been parked for three weeks. When started it fired right up but the idle dropped below 500 rpm quickly after that initial startup rev. It seemed to struggle to catch itself. It went through three or four almost stall or coughing spells before I gave it a few revs and then all seemed fine.
With all this talk of oil pump failure and electrical gremlins I’m throwing out a lifeline to make sure my issues aren’t related. It’s 100% stock and under warranty but I’d rather not if you know what I mean.
18’ ZL1 stock
700 miles
Started in sport mode with AC and everything off (if that matters).
Last question, what’s your idle oil pressure?
ZL14ME is offline   Reply With Quote
Old 07-13-2018, 05:49 PM   #2
JRS
JRS's Avatar
Drives: 16 camaro M6/ 18 ZL1 camaro A10
It's possible the fuel in the line wasn't the freshish because these cars don't use a return line anymore to move fresh fuel from the tank into the line right away. Another words the initial fuel was stale (three week old fuel is stale no matter what anyone says) causing it to run rough until you revved it up and moved some fresh fuel into the line from the tank. Just my 2 cents.
As for idle oil pressure it is close to 40 psi.
Did it start and run normal the next time? If so this just proves my point, if not it may be a underlying problem.
JRS is offline   Reply With Quote
Old 07-13-2018, 08:01 PM   #3
ZL14ME
Drives: 2018 ZL1 M6
It did seem to run fine afterwards. I thought, at one point, I had an issue but I had just turned the AC off and dropped that compressor load off the engine. I was probably a little hyper sensitive to the issue.
I didn’t realize that about the fuel lines. Thanks for the reply.
I noticed my oil pressure slightly above the hash mark right before 40 psi at idle. So... 32...33ish psi. I also noticed the rpm to be around 750. What’s weird is I have a picture of my dash where the car is idleing several months back and it was at 1000rpm and 38ish psi.
I’m probably making this a bigger deal than it really is but all that oil pump failure has me paying attention.
Old 07-14-2018, 02:20 PM   #4
unavailablezl1
unavailablezl1's Avatar
Drives: 2019 Silverado Z71 6.2L A10
I’m sure it is fine. Mine was a little rough but now 4000 miles on it. It is getting smoother all the time
Current ride
2019 Silverado Z71 LTZ 6.2L L87 425hp A10, 4 inch BDS Lift with Fox Factory Race 2.5 Coilovers, Borla Cat back (15HP bump), BFG KM3's 33's.
Past Rides
2017 M6 Camaro ZL1 Hyper Blue
2016 M6 GT350 White with blue strips
2014 M6 Mustang GT Premium Track Pack Ruby Red
2012 M6 M3 Melbourne Red Metallic
unavailablezl1 is offline   Reply With Quote
