![]() ![]() ![]() ![]() Drives: 2018 ZL1 A10 Join Date: May 2012
Removing Burnout Debris
What is the best way to remove the rubber and burnout debris left on your car after a night of racing?
DAVENPORT STAGE 2 PLUS - 2" ARH ceramic coated headers - 3" ARH catless exhaust - Stock NPP mufflers - Kong ported SC - Katech 103 ported TB - Rotofab 5" Big gulp CAI - 22.5% lower pulley - ATI Harmonic balancer - Cordes SC expansion tank - MSD hi temp ignition wires - Koolsox spark plug insulators - custom tunes - 660hp/725tq pump - 713hp/763tq race
![]() Drives: 2016 Camaro 2SS Join Date: Jun 2017
water soap and clay bar are my way to remove those rubber on rocker panel after track day
Stoner Tarminator works well, just don't use it on plastic trim. It will remove your wax/sealant, so you'll need to reapply.
I like to use Road Warrior Paint Protection, put in on before you go, it comes off with water. https://www.camaro5.com/forums/showthread.php?t=498958
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, 3.91 gear, Eaton True-trac, DSS 1000hp axles. |
![]() Drives: '19 ZLE, S54 E36M3 Join Date: Feb 2018
I use Spartan SD-20 (available from your local janitorial supply house) on my race car. The Porsche guys swear by Mothers R3.
BAMF SS
Painters tape
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
![]() Drives: . Join Date: Oct 2008
For the inner fenderwells (the felt-like material), I coat them with aerosol spray wax before the race. The wax soaks into the felt and keeps the rubber and track goo from setting into the material. After racing, you can use a soft brush or your hand (with a glove) and clean it off. It works best if you brush/rub in small circles.
I also coat the suspension components with spray wax and the junk comes right off with the paper towels. The wax is the same miracle wax they sell from popup tents in gas stations. I just buy it cheaper by the case online. |
#7 |
![]() Drives: 2017 ZL1 A10 Join Date: Nov 2009
WD40 will melt the rubber off.
#8 |
![]() Drives: 2018 ZL1 1LE 2022 GMC AT4 HD Join Date: Dec 2014
Mothers 3R(Race Rubber Remover)
#9 |
![]() Drives: 2018 Camaro ZL1 1LE Join Date: Apr 2015
Turtle wax Bug and tar remover works great
#10 |
![]() Drives: 2017 50th Anniversary Join Date: Dec 2015
WD40 is the easiest and cheapest option i've ever tried.
#11 |
![]() Drives: 2024 Toyota Camry XSE Join Date: Sep 2017
Little pricey but works well.
2016 1SS - Bought: 8/2017 Sold: 12/2023
#12 |
Moderator
Griot’s Track Spray works mint:
https://www.griotsgarage.com/product/track+spray.do
