Old 07-06-2018, 09:23 AM   #1
Vsoles
Vsoles's Avatar
Drives: 2016 Summit White 2 SS
Unhappy SOMETHING ISN'T RIGHT ABOUT MY TEXAS SPEED HEADER INSTALL (COULD USE HELP!)
What's going on everyone? I recently got my Texas Speed 1 7/8 headers and x-pipe installed on my car earlier this week. I'm highly impressed with the quality and my car truly sounds like a v8 now, if anyone is on the fence. Anyway immediately after my installation I noticed that my steering wheel felt different. As I got on the gas my steering wheel became very tight and won't return to it's neutral position after turning corners. Feels like my forearms are getting a work out when I drive my car and it's bothering the hell out of me. I went with a well reputable shop, but the guys insisted using the stock steering column bolt besides the one provided since one brother vouched for the other that he has plenty of experience with 6 Gens. Granted the only thing touching my headers is 2 spark plug wire boots, but still is there any explanation for this? Any help is much appreciated! I went ahead and ordered another bolt from TSP btw and I also unplugged my battery to see if it would reset
Vsoles is offline   Reply With Quote
Old 07-06-2018, 09:41 AM   #2
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
The stock steering shaft bolt is hitting a primary on the header. Common issue with TSP headers. They are suppose to use the button head bolt that clears.
Old 07-06-2018, 09:58 AM   #3
Vsoles
Vsoles's Avatar
Truly hope that this is the problem. I'm sure they tossed the original to the side or whatever the case may be. I will find out first thing tomorrow morning, but I ordered another bolt anyways. Great way to start of my 30's smh!
Old 07-06-2018, 11:06 AM   #4
jdasnt3
jdasnt3's Avatar
Drives: 18 Silverado 1500
So the bolts that needed to be used weren't used because one brother "vouched" that the other brother has plenty of experience on 6th gens? It sounds like when everything was cold, it had clearance, but now that it has heated up it doesn't. Hence the need for the included bolts regardless of how much "vouching" went on.
Sorry that you paid all that good money and had an issue with the install, OP. I'm sure they'll take care of you, but it shouldn't have happened in the first place. Are you using high temp boots for the plugs? If not, some on here have had heat issues on the plug wires.
Old 07-06-2018, 11:17 AM   #5
Vsoles
Vsoles's Avatar
Pretty much. When I mentioned it to them they assured me that it wasn't needed. It's all good man, it's always my luck. They don't have a choice cause I can barely drive my car. I'm going to look into the msd spark wires with the 45 and 90 degree angles
Old 07-06-2018, 12:03 PM   #6
parbreak
Drives: 2017 50th Camaro SS
I would still put heat sleeves on the wires. I used DEI.
50th Anniversary Edition |Borla Atak and 60606 mid pipes| Kooks 1 7/8" | ProCharger Stage II |305/45/17 DRs | Circle D 3500 stall | LT4 fueling | Custom made Lowside Aux Pump | Alky Control Meth | DSX E85
parbreak is offline   Reply With Quote
Old 07-06-2018, 01:23 PM   #7
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
Dude your steering is binding.. VERY UNSAFE
Old 07-06-2018, 03:00 PM   #8
Vsoles
Vsoles's Avatar
Ill look into it
Old 07-06-2018, 03:01 PM   #9
Vsoles
Vsoles's Avatar
I don't know how to fix it man. Really sucks! Hopefully everything will be fine once I replace that bolt.
Old 07-06-2018, 06:48 PM   #10
EMTNLSS
EMTNLSS's Avatar
Drives: 2016 Hyper Blue 2SS
I have these headers also and only get rubbing on hard right turns. I can barely feel it in the steering wheel and it gets tighter. This is with the bolt replaced. I'm not sure if it's the actual header rubbing or maybe the other stock bolt. I need to contact TSP and see what they say.
2SS Hyper Blue Metallic | A8 | Jet Black Interior | NPP Exhaust
Current Mods: Catch Can | aFe Lowering Springs | GM 2nd Gen Splitter | Hotchkis Sway Bars | MRR FS02 Wheels | Flowmaster Exhaust | Dark Tail Lights | Diode Dynamics Sidemarkers | Roto Fab | Solar TB | PRAY Ported IM | BMR | PRAY Tune
Upcoming Mods:
EMTNLSS is offline   Reply With Quote
Old 07-07-2018, 11:37 AM   #11
Vsoles
Vsoles's Avatar
I’m at a point where I want to take them right back off. The muffler shop where I got them installed has no clue what’s causing the problem
Old 07-07-2018, 03:25 PM   #12
Goohead
Horsepower whisperer
Drives: Camaro
Having issues with a 2” set as well, was shipped the wrong bolt, also the mid of steering shaft is constantly touching the headers
Waiting on them to get a set in to hopefully replace
Goohead is offline   Reply With Quote
Old 07-07-2018, 07:55 PM   #13
EMTNLSS
EMTNLSS's Avatar
Did they say they'll replace it?
Upcoming Mods:
Old 07-07-2018, 09:20 PM   #14
FIFTY017
Drives: 2018 Silverado Z71 TxEdition
Yup!!! i posted a thread on here a couple mths ago. same issue. mine was running on the bolt which wasnt sent to the performance shop that installed mine. I talked to Russell who was an amazing help. sent me the .40 cent bolt for free overnight. took me 2 sec's to swap out and no issues. now if your getting binding that rubbing the whole steering column thats diff. I have the 6.2. if the bolt is the issue than thats an easy fix.
that last pic does look like the column is literally rubbing the header. mine has a pinkie width after i replaced the bolt.
FIFTY017 is offline   Reply With Quote
help me please, texas speed & performance, texas speed headers
