Old 07-02-2018, 10:20 AM   #1
PatrickRodriguz
Drives: 2018 SS
Active Fuel Management Issue
Hello all,
I wanted to know if the following issue is happening to any of you with AFM.
When the car switches from V8 mode to V4 (AFM) there is a metallic gurgling sound coming from the driver's footwell. I have noticed the noise is present when V4 mode (AFM) is enabled, and the instant L/100KM is above 9L/100KM.
If anyone has a solution, suggestions or the same problem apparent, please let me know in the comments.
Thanks!
PatrickRodriguz is offline   Reply With Quote
Old 07-02-2018, 10:41 AM   #2
SSJ455
SSJ455's Avatar
Drives: "Kara Zor-El" 2017 2SS HBM
Are you sure it isn't just the sound of the engine? I get something similar and to be it is just the sound the engine makes when it switches to V4.
Lead me not into temptation. I already know the way.
Lana? Lana? LANA! LAAANAAAA!!!!
What?
Dangerzoooooone.
SSJ455 is offline   Reply With Quote
Old 07-02-2018, 11:21 AM   #3
HackSaw
HackSaw's Avatar
Drives: 2017 Camaro SS
Its the sound tube Look up above the gas pedal on the firewall there is a hole. Stuff a piece of foam in it
HackSaw is offline   Reply With Quote
active fuel management, afm, issue, noise
