![]() Drives: 2018 ZL1 Join Date: Sep 2016
377 or 416 CI
I am in the position to upgrade the engine in my ZL1. I was originally aiming to do a 416, but recently have been told by multiple people that a 377 would be better. So I'm trying to figure out the difference between the two. Pros and cons. Mods are full bolt ons, ported heads, cam, whipple and fuel/meth and is mostly a drag car.
If your gonna rebuild the motor, 416 would be my choice.
![]() ![]() Drives: '16 2SS / '05 SRT10 Ram / '65 bu Join Date: Dec 2015
No replacement for displacement.
![]() Drives: Chevrolet Camaro SS Join Date: Mar 2015
Unless you're willing to throw on a bigger blower I'd stick with the 377
![]() Drives: Camaro 17 SS Join Date: Jan 2017
416. Is the route I would go.
#7 |
![]() Drives: 2016 Camaro SS Join Date: Jul 2016
I was in the same position. I went 377 for high rev power.
#8 |
Big bore short stroke and high rpm is what I would do...so 377 gets my vote.
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 SS Join Date: May 2013
All depends what setup you are after, I'd vote 377ci underboost vs the 416ci.
#10 |
![]() Drives: 2017 Camaro SS 2SS Join Date: Jun 2017
I'm a torque kind of guy. I would do the 416!
#11 |
![]() Drives: '17 1ss Join Date: Jun 2017
Make sure you have enough meat in The piston. Compression height...
#12 |
Thank you for the info
#13 |
![]() Drives: 1987 Buick Grand National Join Date: Mar 2016
Personally am a fan of the stock stroke on these motors. I would do a 377 as well.
#14 |
for me, I have a centri and small blower cam, I'd go 416, if I had a twin turbo and a high RPM cam, I'd do with the 377, if I had a PD setup dunno, probably a 377, NA it WOULD be a 416 no doubt in my mind on the last one.
