Old 06-30-2018, 07:18 AM   #1
gsbeavis
Drives: 2020 Camaro 1SS
Scared of A8.......
Looking to pick up a new SS Camaro soon and only recently tried one with the A8. I liked it but I am concerned about reliability. I like a M6 and don't mind it at all but if I thought I could trust the automatic I would consider one. With all the TC issues should I stay away from the automatic cars?
gsbeavis is offline   Reply With Quote
Old 06-30-2018, 07:22 AM   #2
Bigdog9586
Drives: 2016 Z06 coupe
Works great with my 2+ year old Z06 with 650hp and also my 17 SS with measly 460hp engine.
Bigdog9586 is offline   Reply With Quote
Old 06-30-2018, 08:35 AM   #3
Magnum922
Magnum922's Avatar
Drives: 2017 Camaro 2SS, A8
I've only had mine a year next month but it's been flawless.
Magnum922 is offline   Reply With Quote
Old 06-30-2018, 09:31 AM   #4
craigss50
craigss50's Avatar
Drives: 2017 Camaro SS Fifty
I have the A8 and had the shutter issue at 4200 miles but all seems fine now after the dealer changed the fluid. If you really don't have a preference save yourself the extra cost of the automatic and get the manual. The A8 is a very nice transmission but I can see why you would be concerned.
craigss50 is offline   Reply With Quote
Old 06-30-2018, 09:42 AM   #5
cmitchell17
Drives: 17 2SS, 8L90, Cam, Heads, E85
I just hit about 45k and the shutter started on my SS, I got the dealer to do the flush three times and everything seems fine now. There is a specific build date when GM switched to Dextron HP fluid, which has a "improved" friction modifier which fixes the issue. It may have something to do with the life of the fluid and time and heat that eventually breaks down the old style dextron fluid causing the shutter to start during the lifecycle. Yes I do have a concern that driving 45k with the old style fluid has reduced or damaged the TCC clutch, but this "damage" is probably so small, negligible and not quantifiable its not worth thinking about.
Besides that everything else is fine I don't think you should worry at all. If you are OCD about things though, the poor NVH (noise vibration and harshness) qualities of the A8 8L80 will drive you crazy. This includes unnecessary hard and clunky 0 throttle downshifts, unnecessarily hard light throttle 3-4 shifts, and general shift quality inconsistencies. These all seem to be control related and not inherent to the mechanical design just due to their randomness in occurrence. I think a large part of the clunks and noise is due to the excessive driveline backlash as well. If you're just a normal person probably wont notice any of this at all compared to another vehicle.
cmitchell17 is offline   Reply With Quote
Old 06-30-2018, 10:03 AM   #6
01pewterz28
#TeamBeckyD
01pewterz28's Avatar
Picked up my SS April 2017 so far no issues but then again I don't have many miles 2600 miles on the car but so far so good. I will put about 900 miles on it in two weeks heading to the fest so we will see.
#TeamBeckyD
**FIFTY HBM 2SS VERT**
Old 06-30-2018, 10:07 AM   #7
Magnum922
Magnum922's Avatar
Does anyone know the build date?
Old 06-30-2018, 11:59 AM   #8
Nated421
Nated421's Avatar
Drives: 2017 50th Anniversary SS Camaro
I've had my A8 Fifty since October 2016(built September 16). I had the shutter issue and had them do the flush asap which fixed it. I believe that was around 11K. I'm now at 17k haven't had issue again, and I don't baby my car when I drive her either. If I had to do it all over honestly I would probably get a M6 simply because its soooo fun rowing through the gears. But I love my car and the a8 isnt to bad.
Nated421 is offline   Reply With Quote
Old 07-01-2018, 04:35 AM   #9
wingchunsifu
wingchunsifu's Avatar
Drives: 2017 2SS A8, 2026 BMW X1 M35i
I swapped out my 1SS M6 for a 2SS A8 and couldn't be happier. I did encounter the vibration and shudder which was remedied after the dealer flush. The A8 is temperamental from time to time. However when its warmed up the speed and feel of the shifts are mind-blowing. Its a faster car with an A8. As fun as manuals are to drive I would never go back to a M6. Way too much work to drive all the time.
wingchunsifu is offline   Reply With Quote
Old 07-02-2018, 07:39 AM   #10
mdhopt36
Drives: '17- 1ag37 V6 traded, for 1SS 2018!
I have the 1SS A8, and so far, flawless performance.... but for only a bit over 3 months. Even in touring mode, it seems to forget all about conservative manners when the proper mashing of the right foot occurs. (shuts up my loudmouth brother!?)
mdhopt36 is offline   Reply With Quote
Old 07-02-2018, 07:47 AM   #11
Koldunic
Drives: 2018 ZL1 1LE
Is there any consensus on the troubles some have with the A8?
Is it linked with the AFM?
Koldunic is offline   Reply With Quote
Old 07-02-2018, 07:57 AM   #12
JT58
Drives: Former 2016 Camaro 1LT
No worries on the A8- Mine initially had the shudder issue and after a flush it has been fine since.
2006 C6 Corvette Manual, 2019 Silverado, 1997 Jeep Wrangler
JT58 is offline   Reply With Quote
Old 07-02-2018, 09:33 AM   #13
DangerZL1
Drives: 2023 Black ZL1 Auto
If you're scared of the A8, then I'd definitely wait and order a 2019 with the A10. A much better transmission with hardly any complaints. This assumes you can get past the horrid looking bumper on the 2019 SS.
Old 07-02-2018, 09:36 AM   #14
Grumpy1
Grumpy1's Avatar
Agreed....
Grumpy1 is offline   Reply With Quote
