Old 06-29-2018, 10:14 AM   #1
Mister Will
Mister Will's Avatar
Drives: 2021 Camaro ZL1 A10
Cat-, Axle- Back Exhaust question.
Hi All,
First, please forgive my ignorance.
Typically in the past with pony cars or corvettes, a "catback" was a no brainer as a first or early mod. Generally they were a simple bolt on. Unbolt the OEM pipes and mufflers and bolt in the aftermarket product.
However, with the exhaust system of the C6 Camaro SS I hear a lot of talk of cutting pipes and welding. I looked under the car and I don't see any flanges between the cats and the mufflers. Do you have to cut the pipes if keeping the cats (primary and secondary) in place are a must? Are the days of the catback being a "bolt on" inapplicable?
Mister Will is offline   Reply With Quote
Old 06-29-2018, 10:17 AM   #2
enzia35
Drives: '16 Garnet Red 1SS
Cutting and clamps.
'16 Camaro 1SS
'18 Miata GT
Old 06-29-2018, 01:01 PM   #3
srcstc
I believe a full cat back is bolt on if you lose the secondary cats.
srcstc is offline   Reply With Quote
Old 06-29-2018, 01:14 PM   #4
17txcamaross
Drives: 2017 Camaro 2SS
Catback is still 100% bolt on if you are retaining all cats. Well, clamp/bolton.
17txcamaross is offline   Reply With Quote
Old 07-01-2018, 10:09 AM   #5
Mister Will
So basically if you want to retain all of the cats, you will have to cut some pipes, correct?
Old 07-01-2018, 10:32 AM   #6
JamesNoBrakes
JamesNoBrakes's Avatar
Drives: 2SS 1LE
Why are you doing an axle-back exhaust in the first place? It adds no power at all. It can make the exhaust louder, but some of that has to do with what is happening upstream of the axles as well. It makes a lot more sense to save up a bit more money and change out more of the system.
2018 2SS 1LE
2023 Colorado ZR2
2022 Stinger GT-line AWD
JamesNoBrakes is offline   Reply With Quote
Old 07-01-2018, 10:42 AM   #7
enzia35
Some people just want a better sound.
'16 Camaro 1SS
'18 Miata GT
Old 07-02-2018, 09:50 AM   #8
Chef-j
Drives: 2018 Camaro 1SS
I see clamps after secondary cat.
https://www.mishimoto.com/engineerin...system-review/
Chef-j is offline   Reply With Quote
Old 07-02-2018, 10:39 AM   #9
Mister Will
This is the primary reason for the question. If there is no power gain, then the only point of changing the exhaust is to change the exhaust tone. I can't replace any components before or including the cats without affecting smog compliance (I don't want to go that route anymore).
In all of my previous cat-backs from a '88 Fox Body Mustang, '98 Camaro Z28, to a '04 Corvette Coupe, all of the bolted on to an existing flange of the OEM exhaust. I would be willing to do and cat-back that was a simple bolt in bolt out.
While I would like to change the exhaust sound to be more muscle car like, I don't want to cut up the stock pipes to do this. I see no real advantage to changing the muffler. So I will probably just keep it stock.
Old 07-02-2018, 11:47 AM   #10
Chef-j
Weight saving
Old 07-02-2018, 01:21 PM   #11
Mister Will
Originally Posted by Chef-j View Post
Weight saving
I don't think we are talking about enough to be significant.
Old 07-03-2018, 10:54 AM   #12
SilverBlueSS
SilverBlueSS's Avatar
Drives: 2017 2SS A8 Hyper Blue
Weight saving
Or not My factory axel back non-NPP weighed 29.4 lbs. The Borla S 27 lbs...
2011 SS-RS L99 A6 Silver w/ Blue Stripes - Sold
best 1/4 time - 13.14 @ 106.30
2017 2SS Hyper Blue
Best drag times.. 60ft = 1.82 1/8 = 7.82 @ 91.51 1/4 =12.10 @ 115.04
SilverBlueSS is offline   Reply With Quote
Old 07-03-2018, 12:04 PM   #13
srcstc
There's no clamps after the secondary cats.
Old 07-03-2018, 01:18 PM   #14
VinnAY
Drives: 18 1SS/1LE
"Track" setting is too tame.
