Old 06-28-2018, 06:31 PM   #1
Redline Motorsports
Redline Motorsports's Avatar
Drives: Several...
Redline Motorsports TVS2650 vs TVS1700 shoot out
So we recently did some independent testing with Edelbrock Superchargers using there new TVS2650 supercharger and stacked it against the OEM TVS1700. As to be expected it performed very well. Much larger case and superior cooling system contributed to the gains. The test was performed on a prior built ZL1 10 speed car we had completed almost a year ago. The car had our PHASE 3 Performance package which kept the factory 1700. I'm sure it will be asked why didn't we do this on a stock LT4 and the answer is we wanted to see this blower work under modified conditions. Its safe to say it clearly out performs the factory blower so an increase is evident.
Here is the formal write up on the swap...
https://www.lsxmag.com/tech-stories/...rger-on-a-zl1/
Redline Motorsports-HT
Redline Motorsports is offline   Reply With Quote
Old 06-28-2018, 09:31 PM   #2
GT-ER
Drives: 2018 Camaro ZL1
Nice. How did you get keep the A/F ratios happy on the stock fuel system (if stock)? By running meth?
GT-ER is offline   Reply With Quote
Old 06-29-2018, 11:03 AM   #3
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
70 wHP and 40 LbFt on the same boost tells the story; the 2650 is clearly a more efficient match for the 6.2L.
Old 06-29-2018, 11:15 AM   #4
ccw
Drives: 2018 ZL1 1LE
What I would love to see is a dyno comparison on a modified motor between the TVS 2650 and 2.9L Whipple.
ccw is offline   Reply With Quote
Old 06-29-2018, 12:09 PM   #5
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
yes Modified whipple vs modified eforce lets see if the claims of are true more flow from a 2650 vs 2.9.. Then stock zl1 with pulleys vs the 2650 setup..
Redline....
Is this going to be a easy swap pull the LT4 1700 off and add the eforce and all the plumbing plugs and just some extensions or harness for the electronics?
or we talking changing damper, tensioners, and other stuff?
Old 06-29-2018, 12:20 PM   #6
ccw
Redline....
I suspect the 2650 will make more torque, but the HP numbers should be about the same. I would also love to see a comparison on manifold intake temps at the same elevated power levels. Eventually we're going to see these back-to-back comparisons, and I can't wait.
Old 06-29-2018, 03:07 PM   #7
DavidStrLondon
Drives: 2017 ZL1
Cooling bricks on stock blower are small.
I have always been obsessed about intake air temps...
Whipple has larger coolers than stock, but that one is even larger!Really interesting!
DavidStrLondon is offline   Reply With Quote
Old 06-29-2018, 03:27 PM   #8
Markoz28
Drives: 18 ZL1 nightfall grey A10
What’s the price difference between the Whipple 2.9 and the eforce 2650? What would be fuel requirements if any? Which is easier to install?
Markoz28 is offline   Reply With Quote
