Old 06-28-2018, 08:17 AM   #1
d729596
d729596's Avatar
Drives: 2016 SS Hyper Blue
Reading Boost
I recently installed my supercharger that included a 3 bar map sensor. I am trying to figure out if a gauge will be able to read boost through the obd 2 connection. Supercharger company said through obd 2 connection it will come through in kpa and needs to be converted to psi. Gauge company says it should come through as bar and they convert it to psi. Any idea on what the answer is? Can I read boost or not?
d729596 is offline   Reply With Quote
Old 06-28-2018, 08:22 AM   #2
Omega
Drives: G8
kPa and psi are just units of boost. Manifold pressure can be read off the com bus and most gauges are able to display your boost pressure in kPa or psi.
Sent from my Pixel XL using Tapatalk
Omega is offline   Reply With Quote
Old 06-28-2018, 10:36 AM   #3
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
I can read boost through SCT or live but I subtract 6.8 I think so If it read 18.5 boost I'm really just under 12 psi
Old 06-28-2018, 10:54 AM   #4
Eyefixstuff
Eyefixstuff's Avatar
Drives: 16’ 2SS A8 HBM Procharged
You can read the boost through software, mine logs it on hptuners. But my gauge I use, I actually have it T’ed into the vacuum port coming off of the intake. It’s really accurate it seems, but I would recommend using an analog gauge. My digital one from AEM seems a little slow.
16' 2SS A8 Hyperblue | P1SC-1, Race IC | JMS fuel pump voltage booster | Jannetty custom tune | Elite E2-X catch can | M017 Wheels
Eyefixstuff is offline   Reply With Quote
Old 06-28-2018, 11:09 AM   #5
hitmix300
2016 loaded 2SS
hitmix300's Avatar
Drives: Maverick X3 Turbo R
On my car, i have a breakout harness so the pcm can see the outside baro pressure and the intake manifold pressure.
I simply use this formula:
intake pressure-baro pressure=boost pressure @ manifold.
see the photo below for my datalog representing both values.
hope this helps in some sorta way.
hitmix300 is offline   Reply With Quote
Old 06-30-2018, 09:50 AM   #6
TJay74
Since I added the D1SC to my car I have been going down this route as well, I finally pulled the plug and just ordered a manual Autometer boost gauge for mine. I wish there was a electronic version that worked better.
The shop that did my install said the standard 1 bar MAP is more than able to read boost, the 3 bar isnt needed unless you are going over 30psi.
Old 06-30-2018, 10:29 AM   #7
Omega
Drives: G8
1 bar = 14.5ish psi. Most people are up near the top end of the 1 bar maps' table so they change to the 3 bar during the upgrade just to avoid future problems. If you're at 12psi and it spikes a bit, you're SOL with the ECU being able to compensate.
