Old 06-26-2018, 11:23 AM   #1
dfwcowboy
dfwcowboy's Avatar
Drives: 2024 ZL1 M6, 1978 Beechcraft Baron
Question about air dams
So my new car came with a set of 4 plastic pieces. There's two air dams for the front part numbers, 23408773 and 23408774. There's also two for the rear which is some kind of rear suspension covers 22823592 and 22823593.
I went back to my dealership to have them installed and was told by the service department that these pieces are only used if you intend to put the vehicle on a track, which kinda sounds like BS to me.
Does anyone have any GM references that describe what these parts are really for and perhaps some real world information on why I would want to install them or not install them? I searched this site and didn't find much information.
dfwcowboy is offline   Reply With Quote
Old 06-26-2018, 11:27 AM   #2
BAMF
BAMF's Avatar
Drives: The Tumbler
Actually, they are correct. In the trunk, you should find a paper with instructions on how to install them. Somewhere near the top of the paper it specifies that they are for track-use only. Leaving them on during regular driving will risk causing damage by allowing more road debris and water to hit the back of the brake assembly.
2017 NGM 2SS, M6, Adrenaline Red interior, NPP, MRC, and a bunch of other nice stuff.
BAMF is offline   Reply With Quote
Old 06-26-2018, 11:29 AM   #3
italiano687
Drives: 2015 Chevrolet Camaro 1lt
The front air dams are stock and found on 6th gen camaros. They should be on the car unless you have some type of modified front. Is this a Chevy dealer telling you this? I will go check my car but I think I have the back suspension cover on my car too.
italiano687 is offline   Reply With Quote
Old 06-26-2018, 11:30 AM   #4
italiano687
That’s only for the back suspension cover, right? The front air dams are for everyday driving.
Old 06-26-2018, 11:47 AM   #5
dfwcowboy
dfwcowboy's Avatar
The only installation paper I found was for the two front sections and it says nothing I could find about track use only.
Old 06-26-2018, 11:59 AM   #6
ChevyRules
Drives: 2021 Tesla Model 3 LR
Your dealer is an idiot.
The front air dams( the part numbers you listed anyway) are what is attached in the picture below right in front of the wheels. To my understanding, they are for high speed aerodynamics in reducing drag therefore improving fuel economy. They should be installed, but not critical to anything. They are NOT the brake coolers others are thinking you're talking about.
As for the rear parts, those are the lower control arm covers. Those SHOULD absolutely be installed. They will prevent mud, dirt, and other debris from building up on the control arm and other components. Those are just not for the track.
ChevyRules is offline   Reply With Quote
Old 06-27-2018, 12:22 PM   #7
BAMF
BAMF's Avatar
Drives: The Tumbler
I’m sorry, are you referring to the items in the red circles here? I wanna make sure I’m talking about the right thing.
Old 06-27-2018, 12:24 PM   #8
ChevyRules
Part number 23408773(4) refers to the items in the second picture.
https://www.gmpartsdirect.com/oem-pa...ector-23408773
Part numbers 22823592 and 22823593 are the lower control arm covers in the back of the car.
https://www.gmpartscenter.net/oem-pa...bC1sNC1nYXM%3D
Old 06-27-2018, 12:33 PM   #9
mcintyre1969
mcintyre1969's Avatar
Drives: 1968 SS/RS, 2006 H2 2016 2SS White
Seems you guys are talking about two different things
2016 2SS White fully loaded
mcintyre1969 is offline   Reply With Quote
Old 06-27-2018, 01:32 PM   #10
BAMF
BAMF's Avatar
Drives: The Tumbler
Ok, completely my fault here, I was mistaken in what I thought you were referring to.
Your dealer is an idiot. Please refer to the first post here by ChevyRules for the correct answer.
Old 06-27-2018, 02:24 PM   #11
Magnum922
Magnum922's Avatar
Drives: 2017 Camaro 2SS, A8
All mine where in the trunk when I got the car last July. I asked them whstvyhey are for . The dealer tech said the lower control arm rear covers are for if you drive in snow or dirt roads to keep debris off the arms. The rest were for racing.
Magnum922 is offline   Reply With Quote
Old 06-27-2018, 06:25 PM   #12
dfwcowboy
dfwcowboy's Avatar
I think I’m going to install the pieces myself.
Old 06-27-2018, 06:51 PM   #13
kpgreenwell
kpgreenwell's Avatar
Drives: 2017 50th anniversary edition v6 A8
Mine were installed at the Chevy Dealership
kpgreenwell is offline   Reply With Quote
Old 06-28-2018, 01:29 PM   #14
Sp00ner
Sp00ner's Avatar
Rear control arm covers = Always On
Brake Cooling Duct (and associated parts) = On for track/summer use.
Front Air Dams = Off for Track Use
Sp00ner is offline   Reply With Quote
