![]() Drives: Mosaic Black 2016 2SS Join Date: Feb 2018
2016 2SS Tire Size Changes
Hey guys, just wondering if I can get some assistance in changing the tire sizing for my car?
I'm currently running 305/30/20s on an 11 inch wheel for my rear setup which should be a 27.2 inch tire.... I went into HP Tuners Gear/Tire wizard after calculating the size and input 27.2 in tire size and stock gear ratio. I left the speedo calibration and scale trans parameters boxes checked with a 1.0 multiplier, saved the changes and wrote the calibration but my speedo was still 2-3mph off. So I went back in and upped the tire size to 28.2, saved, wrote, same issue. Still 2-3mph off what my GPS speed is saying on both my phone and radar detector. I'm just wondering if there's something I missing here as to why the tire size change isn't bringing my speedo reading into line with my GPS speed? Do I need to perform a write entire?? Any help on this would be much appreciated and I thank you in advance! |
![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS Join Date: Aug 2016
The place in HPT where I've made a speedometer correction successfully is the Speedo tab, Calibration, VSS tire revs per mile. Have not tried this wizard that you are talking about. Write calibration worked fine for me with a change to this parameter.
![]() Drives: Yellow 2018 SS Join Date: Jun 2011
What GPS system are you using to detect speed?
AFAIK most, if not all, GPS systems have an issue being 100% accurate on speed due to the way GPS works. There's a bit of delay with GPS and that delay can cause problems if you're using it to detect speed. |
#4 | |
I did play around in HPT some more than and decided to go down in size rather than up. It seems setting the tune to a size of 26.4 has me back to being synced with GPS speed again. I'm not sure why I need to set the size almost a full inch smaller than what I'm actually running to get the reported speed correct, but as long as it's reading properly again, I'm happy. |
SNSTRSS
After making change to tire wizard do you do a full write of ecm and tcm?
2016 Black Camaro 2SS A8 NP
No. Just write the calibration.
#7 |
SNSTRSS
Do I select both ecm and tcm?
#8 |
ECM only
#9 |
SNSTRSS
Thanks
