![]() Drives: 2017 Camaro 2SS A8 Join Date: Jul 2016
Is Stealth exhaust mode damaging at the track?
In the owner's manual, there is a single reference to using the Stealth option on our Engine Sound Management setting.
"The Engine Sound Management setting (if equipped) should not be set to Stealth Mode during track events and competitive driving." My question is if this is mentioned because it is damaging to the dual mode exhaust valve or simply letting you know to keep it off for performance/lower restriction reasons? This is pretty important for tracks with decibel limits, particularly Laguna Seca's 92dB limit. It would be great to know we can leave it on Stealth safely so that we can focus on driving rather than staying under sound check station limits.
TPNS5F
7/11/16 - 1100 - Ordered 2017 2SS at dealer 8/7/16 - Order requested to be cancelled TRBTXD 8/9/16 - 2000 - New order placed 8/10/16 - 3000 ~8/16/16 - 3400 9/20/16 - 6000 Delivered to Customer (That's me) |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1ss camaro Join Date: Feb 2016
long tubes and exhaust with npp on the track is awesome lol let those bald eagles fly
#3 | |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
Norm
'19 WRX 6M (the family sedan . . . seriously) |
![]() Drives: '16 Z06 7 Spd, 2024 High Country HD Join Date: May 2015
Try setting it in "Tour". Should be much less restrictive and louder than Stealth but not nearly as loud as Track or Sport and should also pass the 92dB limit
All the modes simply alter when the valve is open or closed.
Tour leaves the valve closed at all time outside of start-up, high RPM and high throttle input. Which means it will be open just as much as Sport/Track mode on the track. If you go WOT, Tour/Sport/Track are all the same loudness. The valve simply opens to the "loud/less restrictive" exhaust path. Closed makes the exhaust go the "quiet/more restrictive" path. Sport/Track modes leaves the valve open in almost all circumstances outside of steady state speed above 10-15 mph with low rpm/throttle (avoids drone). Track opens up with even less RPM and throttle than Sport. But as I mentioned, when you are going WOT at the track, Tour will not make a difference outside of some braking zones where you are off throttle. But that doesn't matter at all since it is about peak loudness which is when you are WOT. Stealth keeps them closed no matter what. The question is if it is damaging, not just lower performance.
TPNS5F
#6 | |
lol only track around here that does that is laguna seca and im nowhere close to it
#7 |
I guess you're fortunate for the most part. For now, anyway.
It would be good to get this question answered for those who face noise limits now. Lime Rock in CT is another track with unusually restrictive sound limits (on most days). Norm
#8 |
![]() ![]() ![]() Drives: 2017 Camaro 1SS, 2023 Colorado Z71 Join Date: Sep 2017
No issues with stock SS's (including 1LE's) w/ NPP in track mode at Lime Rock
https://www.camaro6.com/forums/showthread.php?t=525538 See page 2 of link for confirmation.
2017 1SS, Summit White, Black 2SS Interior, MRC, NPP
2023 Colorado Z71, Nitro Yellow |
#9 |
![]() Drives: Zl1 1le Join Date: Jun 2017
#10 |
![]() Drives: 2020 Camaro ZL-1 1LE Join Date: Jul 2018
#11 |
Drives: 2011 2SS/ RS INFERNO ORANGE L99 Join Date: Dec 2012
Is there a team Camaro rep anywhere on this thread. The members now know more about the 5th gen then anybody.
#12 |
Driver for Hire
I’m curious what NCM did to help you pass and keep running. I know when I was there, they said “if you blow sound, we will help get you down to the 103dB limit, we want you out on the track.” Also, what did you end up running there?
Luan Zeqollari
2022 Camaro 2SS 1LE M6 - Wild Cherry Tintcoat 2018 Camaro 1SS 1LE - Hyper Blue Metallic - RIP 6/6/20 YouTube Channel |
#13 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
"Do not place the vehicle in Engine Sound Management – Stealth mode. Damage could result to exhaust valve actuators." https://my.chevrolet.com/content/dam...ers-manual.pdf I'd say the systems and actuators are similar enough that this probably applies to the Camaro as well and answers your question.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
#14 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 SS 1LE, 2017 Volt, 2013 Pilot Join Date: May 2014
if warning is for damage to actuators, leave it in track and block the outer pipes...bananas or something?
