Old 06-25-2018, 11:01 AM   #1
protovack
Drives: 2019 2LT 2.0T M6 Riverside Blue
Crushed my rocker panel using ZL1addons jack pad [UPDATED]
So, I just received my camaro jack pad with mag puck and the rock guards. To install the rear rock guards, I had to lift the rear wheels. I placed the jack pad on the pinch weld with the mag puck underneath. I was on level ground, the jack pad seemed to be in the correct position. After about 5 cranks on the lever, the jack pad rolled off the pinch weld and the jack slipped outwards onto the underside of the rocker, crushing it!
I'm a little confused--the groove in the jack pad is much wider than the pinch weld, and it very clearly rocks back and forth while adhered to the pinch weld.
Here is a pic from under the rocker panel.
I already contacted ZL1addons, and am awaiting their response. I just wanted to see if anyone else had this issue.
protovack is offline   Reply With Quote
Old 06-25-2018, 11:13 AM   #2
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
Is this the new style pad with the screws or the older one without.
The old one was a faulty design which could roll off, mine has done it before but no damage.
Old 06-25-2018, 12:36 PM   #3
HackSaw
HackSaw's Avatar
Drives: 2017 Camaro SS
Part of the problem will always be the arc of a floor jack when it lifts. If the jack doesnt roll forward as it lifts it tends to pull outboard.
HackSaw is offline   Reply With Quote
Old 06-25-2018, 01:04 PM   #4
booyaa56
booyaa56's Avatar
Drives: 2017 Camaro 1LE
Wow, never had that problem? Maybe it was the jack stand just like BradfordCamaro mentions
booyaa56 is offline   Reply With Quote
Old 06-25-2018, 01:06 PM   #5
Allez
Allez's Avatar
I had something similar happen because of the jack not rolling forward. I've learned since then to check to make sure the puck doesn't start to lean with each pump of the jack. Mine occurred with a generic pinch weld adapter.
Allez is offline   Reply With Quote
Old 06-25-2018, 02:14 PM   #6
protovack
Does it even matter if you bend over the pinch welds down there? Does that cause any structural integrity loss? Because as far as I can tell, if you just jack it up on the pinch weld, it eventually bends and flattens out a bit.
Old 06-25-2018, 02:43 PM   #7
Allez
Allez's Avatar
From watching the ZL1addons instructional video, when you have the car on the jack the edge of the pinch weld is supposed to rest on the bottom of the groove of your adapter or puck - that is what supports its weight. The metal on the car that is on either side of the pinch weld is not supposed to be supporting the car.
Old 06-25-2018, 03:22 PM   #8
protovack
I guess what I'm asking is, what will happen if I just continually use my jack directly on the pinch weld. Because I've not ever seen a thread or pictures documenting any damage beyond the pinch weld being bent over on itself slightly. I know it seems bad to do that, but is there any direct evidence that this process compromises structural integrity?
It just seems odd to me that they would build a car knowing it is going to be jacked up, and worked on by enthusiasts at home fairly frequently, and put pinch welds on it that are not structurally sound and require aftermarket parts in order to jack up the car. It just doesn't make sense. So my thoughts are, that its probably sturdy enough to just be jacked on the pinch weld and its not as big a deal as people make it out to be.
And not only that, my jack happens to have a fairly small cup and fits on the rear jack point pinch weld. But larger, sturdier floor jacks have larger cups or plates, and certainly would not be able to hit the pinch weld without hitting other structures like the rocker panel. So they would HAVE to buy aftermarket items just to jack the car.
I just don't get it.
What do people do who aren't car enthusiasts and know their vehicles to the extent we do? All the people out there with base 4's and 6's, what if they break down and have to jack their car on the side of the road? It seems like they run a good chance of destroying something and creating a warranty claim. Why would GM not put a sturdy, from-the-factory area to place a jack??
Old 06-25-2018, 04:03 PM   #9
mbar
Drives: 2016 1SS
Same happened to me
1SS, Black, Black Wheels, A8, MRC, NPP
mbar is offline   Reply With Quote
Old 06-25-2018, 04:26 PM   #10
fighting irish
The Doctor is in
fighting irish's Avatar
Drives: 2016 Camaro 2SS Nightfall MRC NPP
Originally Posted by mbar View Post
Same happened to me
Me three.
2016 2SS MRC NPP Sunroof Nav, Forgestars CF5V with RE-71r 275/35r19s in front and 285/35r19s in rear
2017 Silverado 1500 LT Z71 Double Cab
2017 Honda Pilot Elite
fighting irish is offline   Reply With Quote
Old 06-25-2018, 05:29 PM   #11
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
Been using mine for 6 months and never had any hint of an issue. Even forgot it was on there and drove to the track and it didn't come off.
Old 06-25-2018, 06:04 PM   #12
cab33
Drives: Viper
This is my solution to the sketchy jacking of the Gen6 Camaro:
https://www.walmart.com/ip/HyperToug...-Jack/33348135
The head is small enough to fit up in the body and it has grooves to locate on the pinch weld.
cab33 is offline   Reply With Quote
Old 06-25-2018, 10:39 PM   #13
Whitespeed
Drives: 2018 1SS 1LE & 1973 Datsun 240Z
I just have a cheap Amazon sourced jack pad with a hockey puck glued to the bottom of it and I've jacked the car up several times with no issues so far. Not a mark on the frame rails. But I've always checked very carefully that it's positioned properly, and I make sure my jack is perpendicular to the car so there will be no resistance to rolling.
Maybe a stone wedged under one of the jack wheels?
Nigel
Whitespeed is offline   Reply With Quote
Old 06-26-2018, 12:34 PM   #14
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
Strongly recommend you get the bolt on lift points.
