![]() Drives: 16 camaro M6/ 18 ZL1 camaro A10 Join Date: Nov 2015
Easy install of new supercharger pulley
I received my 2.30'' grip tech pulley today and wanted to install it without having to do a lot of work like pulling the supercharger off.
Getting the old pulley off was the hard part. I tried pulling it with a three jaw puller and that wasn't happening so I cut the pulley on both sides with a die grinder then used a puller which it still was tight but it moved. I could have bought the right puller but I wasn't spending $$$. After getting it off I found the pulley was galled to the shaft which is why it was so tight. I put the new pulley adapter in a regular oven and heated to 550 degrees. I pulled it out and put it right on the supercharger crank. It went right on like butter but don't wait too long because it was tight in about 10 seconds. On another note I took it afterward without doing any tuning and it was very noticeable. I used to have clouds of black smoke when I got on it but now it is a lot less. I will check it out with the hp tuner later to see if it is going lean but it doesn't seem to be. I'm sure I will get some flack for this. Can anyone constructively tell me if they had to make any major changes in the fuel enrichment because I know this is a hot topic with some people. |
#2 | |
![]() Get it tuned. ASAP. Any reputable tuner will tell you it's BARELY safe enough to BABY a car with a pulley on stock tune to the shop staying OUT OF BOOST and if the shop is less than an hour away. Anything more than that and it's not worth it. High RPM usage or extended driving amounts = big no no. Don't ask me why. Just listen to the people that have gone before you. Call up a local tuner and ask him how safe it is to get after a pulleyed + stock tune car. If he doesn't hang up immediately, he'll tell you to baby it to the nearest tuner. |
![]() Drives: 2018 ZL1 1998 SS 1992 Typhoon Join Date: Nov 2015
It all changes for each car. There is a gentleman in my neck of the woods that has been running and logging a 9% lower on his C7Z wth the stock tune and no issues. Our DA is 5000+ out here.
I mostly wanted to comment on an easy way to install a supercharger pulley without many tools.
In my area there aren't many tuners and especially ones that know anything about lt1 / lt4 engines specifically plus it is something I'm capable to do myself. I just wanted to know from anyone that does any of their own tuning did they have to make radical changes because I can't see it. I didn't really get a good chance to run the car today as it was rainy wet all day but when it is dry I will definitely check it over. I figured I gained about 2 psi of boost total because it was pushing 11 psi at wot. I appreciate the comment so far. |
Train Driver
Drives: 2018 Summit White ZL1 1LE Join Date: Jun 2013
If this is your only power mod then you should be okay.
You've not changed the VE (Volumetric Efficiency) on the car. So the MAF will see the additional air mass, and adjust fueling accordingly. The MAF transfer is still proper unless you've changed the intake. If you've added headers, or removed cats, then you might have a problem since these change the VE. I hope you are on 93 octane. My $.02
2018 Camaro ZL1LE
/ / Katech TB // RotoFab Dry // Borla 60606 // ATI Super Damper / / |
This is the only real mod I have made other than a ported throttle body and green air filter for what that's worth. I always use 93 octane.
This car seems to be pretty rich as it was because I could wash it and within 15 mins my tailpipes are coal black. I will check my afr later when the weather is nice to make sure it is in the safe zone. |
#7 |
Dyno Show Queen LOL
Good write up, I did the lower just so I wouldn't have to mess with removing the blower not that I couldn't.
Question why does the snout have to come off to remove the pulley again? After reading this, I may do the upper now with a DSX AUX pump and call it done until my 2650 is ready.
#8 |
aka BeastZL1
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra Join Date: Dec 2017
I would not recommend to anyone to put a pulley on without tuning and then get into boost.
#9 |
![]() Drives: 2017 ZL1 A10 Join Date: Jul 2014
#10 |
aka BeastZL1
Missed putting the word "NOT" in the sentence.
#11 | |
aka BeastZL1
How many "natty lights" is a cut off the stock supercharger pulley job?
#12 |
#13 | |
The biggest hurtle was just getting the old pulley off. I hope this helps if you decide to do a pulley swap. |
#14 |
I only asked for constructive comments.
Just sayingI did take it out today and did several wot pulls without so much as a ping, rattle, lights or reduced engine power. I will continue to check it out to see if it needs more fuel but in 80 degree temps it seems fine, I'm not saying on a 100 degree day with no humidity it will still be fine only time will tell. |
