![]() Drives: 2017 camaro 2ss Join Date: Dec 2017
2017 Camaro A8 bolt on’s dyno
Finally got the car tuned after installing some mods. Numbers seem kinda low... 432hp 455tq. DA was 2700, temp was 75 degrees and 88% humidity. what do you guys think?
Mods: 2” ARH long system with no cats Hooker black heart axleback RotoFab CAI with dry filter Ported throttle body Ported intake |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 14 Silverado LTZ Z71, 16 Camaro SS Join Date: Nov 2009
that's about right if they used 5th gear instead of 6th and you are on 93 not e85
SABIO
I look at those mods and think +40hp.
So your baseline was probably 390s. Normal. All good. Not sure why your TQ drops like a rock just before 5K?
So this is normal for a 5th gear pull?
BAMF SS
Can't tell if we dont if a correction factor was used, andif so, which one.
SAE and STD correction takes DA mostly put of the equation and makes it easier to compare dyno runs.
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
5th gear pull is 25whp less, so you would be 455-460whp in 6th, then add E85 and you would be 480-485whp. Sounds spot on imo.
#7 |
Tuner said it was a 6th gear pull but in the vid I took I only counted him going into 5th. So if it’s a 6th gear pull it sounds a little off.
